ASA 5512 Port mapping problem
   Access to the internal server internal use public IP address
asa 5512 ios 8.6.1
Everyone's tags (2)
Bronze
Can you further elaborate on your question.
Have you configured the NAT and ACL.
Can you run a packet tracer:
Assuming the external interface name is outside and the connection is on port tcp/80;
packet in outside tcp 8.8.8.8 1025 server_public_IP 80
Felipe.
Remember to rate useful posts.
Hi Qiu,
If I am understanding you correctly you want to access internal server from behind same interface on it's public ip. If that is the case you could do the following configuration:
Suppose server internal ip is 1.1.1.1 and it's public ip is 2.2.2.2 and server is behind inside interface.
object network obj-1.1.1.1
host 1.1.1.1
exit
object network obj-2.2.2.2
host 2.2.2.2
exit
nat (inside,inside) source dynamic any interface destination static obj-2.2.2.2 obj-1.1.1.1
Hope that helps!
- Prateek Verma
203
