ASA 5512 - slow RDP over VPN and slow https via the outside interface
Hey all,
got the following problem:
We got a new ASA 5512 (9.1(2)). Since using the new ASA RDP over VPN is slow as hell. Furthermore we are hosting services for our customers at our local site. The customers access their servies via https and they report slow connections as well.
What I could determine:
- RAM and CPU usage is OK
- Internet connection is not working to capacity
- Accessed servers are fine
With our old PIX we didn't have these problems.
What can I do to narrow the things down? Do you need further information?
Thank you in advance.
1 ACCEPTED SOLUTION
Super Bronze
Re: ASA 5512 - slow RDP over VPN and slow https via the outside
Theres a problem with your "outside" interface.
  Auto-Duplex(Half-duplex), Auto-Speed(10 Mbps)
Its on Auto/Auto settings and has negotiated 10Mbps/Half Duplex
Check the connection/settings between ASA and the device connected to WAN.
- Jouni
Super Bronze
I would go through the ASAs interfaces so that there is no errors and problems with Duplex.
If there is no problem with the actual physical interfaces then I guess you could capture traffic on either the hosts or on the ASA and go through the traffic capture to see if there is any clear indication of the cause of the problem.
If you are sending ASA logs to a Syslog server then I would also go through the syslogs to see if there is anything special related to these connections.
- Jouni
Are you using the cisco vpn client / anyconnect?
Keep in mind that you got two problem, could be related to duplex/speed mismatich like JouniForss is reffering to.
Hello Sander, Hello JouniForss,
thank your for your answers.
There should be no duplex/speed problems:
Interface GigabitEthernet0/0 "outside", is up, line protocol is up
  Hardware is i82574L rev00, BW 1000 Mbps, DLY 10 usec
        Input flow control is unsupported, output flow control is off
        Description: outside
        MAC address 7cad.746f.0643, MTU 1500
        IP address x.x.x.x, subnet mask 255.255.255.252
        44690985 packets input, 14246179318 bytes, 0 no buffer
        Received 24 broadcasts, 0 runts, 0 giants
        29 input errors, 0 CRC, 0 frame, 29 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        0 L2 decode drops
        36677961 packets output, 30273069571 bytes, 688 underruns
        0 pause output, 0 resume output
        0 output errors, 762873 collisions, 1 interface resets
        3584466 late collisions, 3893361 deferred
        0 input reset drops, 0 output reset drops
        input queue (blocks free curr/low): hardware (493/415)
        output queue (blocks free curr/low): hardware (508/0)
  Traffic Statistics for "outside":
        44690833 packets input, 13414186271 bytes
        40263115 packets output, 34063912416 bytes
        1273840 packets dropped
      1 minute input rate 192 pkts/sec,  173728 bytes/sec
      1 minute output rate 128 pkts/sec,  65991 bytes/sec
      1 minute drop rate, 1 pkts/sec
      5 minute input rate 166 pkts/sec,  104644 bytes/sec
      5 minute output rate 140 pkts/sec,  97204 bytes/sec
      5 minute drop rate, 1 pkts/sec
Interface GigabitEthernet0/1 "inside", is up, line protocol is up
        Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
        Description: inside
        MAC address 7cad.746f.0640, MTU 1500
        IP address 192.168.x.x, subnet mask 255.255.255.0
        273517054 packets input, 33507078716 bytes, 0 no buffer
        Received 1853084 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        505155136 packets output, 673862376054 bytes, 0 underruns
        0 output errors, 0 collisions, 1 interface resets
        0 late collisions, 0 deferred
        4 input reset drops, 0 output reset drops
        input queue (blocks free curr/low): hardware (462/414)
        output queue (blocks free curr/low): hardware (500/414)
  Traffic Statistics for "inside":
        273517049 packets input, 27143885172 bytes
        505155136 packets output, 664727704962 bytes
        384747 packets dropped
      1 minute input rate 47 pkts/sec,  11867 bytes/sec
      1 minute output rate 65 pkts/sec,  43224 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 91 pkts/sec,  28339 bytes/sec
      5 minute output rate 119 pkts/sec,  105353 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface GigabitEthernet0/2 "DMZ", is up, line protocol is up
        Description: DMZ
        MAC address 7cad.746f.0644, MTU 1500
        526650415 packets input, 699849187640 bytes, 0 no buffer
        Received 218607 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        293676989 packets output, 36082728609 bytes, 0 underruns
        input queue (blocks free curr/low): hardware (476/432)
        output queue (blocks free curr/low): hardware (508/425)
  Traffic Statistics for "DMZ":
        523567643 packets input, 687409385731 bytes
        293676989 packets output, 29375410165 bytes
        5136626 packets dropped
      1 minute input rate 86 pkts/sec,  87216 bytes/sec
      1 minute output rate 76 pkts/sec,  7567 bytes/sec
      1 minute drop rate, 18 pkts/sec
      5 minute input rate 86 pkts/sec,  81140 bytes/sec
      5 minute output rate 75 pkts/sec,  6688 bytes/sec
      5 minute drop rate, 16 pkts/sec
I'm using the cisco vpn client (5.0.07)
Super Bronze
- Jouni
Hey JouniForss,
wow, I totally missed this :/
Should be enough to set this to full and 100 Mbps?
Super Bronze
Can you check/set the settings on the device connected to the "outside" port of the ASA also?
I guess it would be good to manually set the speed/duplex settings on the devices.
- Jouni
The other device is a router from our provider. It's not possible to see anything or to configure things on this device :/
I will try to set the duplex/speed settings manuall today in the evening and will report back tomorrow .
Thanks again to you both.
Super Bronze
Were you able to get this problem solved by changing the physical port settings?
- Jouni
Sorry for my late answer.
Indeed it's working fine now. Thanks for seeing my missed missconfiguration
Super Bronze
Good to hear its working now
- Jouni
Depends on your switch side. Please post the configuration
- show run interface fast 1/0/X
and the
- shwo interface fast 1/0/x
Re: ASA 5512 - slow RDP over VPN and slow https via the outside inte
I have same problem after ASA 5585-X update (from version asa963-1-smp-k8.bin to asa982-smp-k8.bin). I`m tryed downgrade software and problem was disappeared. I think that the problem with inspections maps or something else…
1283
