Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5512-x in single transparent mode
I have a unique issue when trying to setup our new 5512-x firewall in single transparent mode. I'm new to ASA world and would appreciate if someone can help me out.
I would like to give a bit of background here.
I work in a university and we have different IT pockets along with central IT. I'm an IT person in one of the pockets and we have our own server closet with vm hosts and some servers. All our hosts and other network resources are connected to a 2960 switch on our end which is etherchanneled  (2 uplinks) to another 2960 switch on central IT end (which I can't control). The central IT switch after all the hoops connects to the edge router for internet access. Here comes the crazy part: In university all IP addresses assigned to each and every resource (servers and clients) are STATIC PUBLIC IPs. We don't use any DHCP or private IP addressing. Within the university all departments and faculties could access each and every resource given they have permission to access that resource. (file server, databases etc). The idea is to block free access and just allow the users that should have access to our resources.
Now the question. Sorry for the length background.
Our server closet is on x.x.198.x subnet. That is where my side of 2960 switch and central IT switch is connected. I want to (if possible) put our  5512-x switch between the two switches and enable the etherchannel on the ASA so that it can let the traffic through with 2GB uplink. Currently, I have setup the ASA in single transparent mode with management IP x.x.198.x subnet. I created a bridge group and tried to give it a x.x.198.x IP but it spit an error about "can't overlap the IPs on same subnet". Since we don't use any private addressing and there is no outside interface (traffic from our area feeds to central IT switches), I'm not sure how to setup a global IP address for inside and outside interface. We have users in 4 different subnets that I want to provide access to our resources located in x.x.198.x. while blocking the rest as well as setting ACL's for our users as well.
Please let me know if you have any questions. I really hope to find some answers.
Thank you so much.
Hello Vaneet,
For each subnet you want to play with you would need a dedicated Bridge Group. That specific Bridge Group will be composed of two layer 2 interfaces having a global management IP address on the ASA Firewall.
Does it makes sense?
Regarding the error,
Can you show us the entire configuration you are entering and after what the error appears.
Looking for some Networking Assistance?
Contact me directly at
I will fix your problem ASAP.
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
Community Member
Thanks Julio for the prompt reply!!
So the ASA has 6 physical interfaces and I need to manage 5 different subnets( all public IPs), how would i go about assigning two layer 2 interfaces per subnet/bridge group. WIll I be creating subinterfaces per physical interface? Also, do I need management interface per subnet as well or not. How can I get the etherchannel to work in this scenario?
I haven't made many changes but here is the running config of ASA:
: Saved
ASA Version 9.1(4)
firewall transparent
hostname SATT-FW-ASA
enable password MSSfG8UVVdoUUa5Q encrypted
passwd MSSfG8UVVdoUUa5Q encrypted
interface GigabitEthernet0/0
nameif Inside
security-level 100
interface GigabitEthernet0/1
nameif Inside1
security-level 100
interface GigabitEthernet0/2
nameif Outside
security-level 20
interface GigabitEthernet0/3
nameif Outside2
nameif Outside2
security-level 20
interface GigabitEthernet0/4
no nameif
no security-level
interface GigabitEthernet0/5
no nameif
no security-level
interface Management0/0
nameif Management
security-level 100
ip address x.x.198.151
interface BVI1
no ip address
boot system disk0:/asa914-smp-k8.bin
boot system disk0:/asa912-smp-k8.bin
boot system disk0:/asa911-smp-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup Management
dns server-group DefaultDNS
name-server x.x.128.1
name-server x.x.64.1
pager lines 24
mtu Inside 1500
mtu Management 1500
mtu Inside1 1500
mtu Outside 1500
mtu Outside2 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-715-100.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http Management
http Management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh x.x.137.0 Management
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption aes128-sha1 3des-sha1
username xxxxxxx password xxxxxxxxx encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
I just enabled the 4 physical interfaces (g0-g3) but they are not physically connected.
So I was trying to assign the first bridge group x.x.198.x IP address and thats when it gave me the following error:
The Ip address x.x.198.153 cannot overlap with the subnet of interface management.
But all of our resources are on x.x.198.x subnet so I need to manage it as well.
I'm sorry if I'm not explaining myself properly. Please let me know if you need more info.
Thanks a lot for helping me out.
Community Member
Hi Julio
Do I have to create a bridge group for each network/subnet that I need to manage? If I have to create a bridge group for each subnet (in total 5 subnets), how can I define an inside and outside interface for each subnet? Do I have to create logical interfaces for each physical interface per subnet? Do I need to create a logical management interfaces per bridge group/subnet?
Also, how can I connect the ASA between two switch that are etherchanneled? Do I have to create an etherchannel on the inside interface of ASA for internal switch (x.x.198.x) and an etherchannel on outside interface for our Central IT switch (x.x.198.x)?
Also, Since I'm not able to assign another x.x.198.x IP address on global configuration because I'm using x.x.198.151 for management port, do i need to remove the IP from management port and manage the ASA through the data ports?
Please help!!
