ASA 5512-X numerous issues
jpdalton1
We have recently implemented a new Cisco ASA 5512-X firewall replacing and old Cisco ASA 5505 Firewall.
We have a number of issues which we are encountering and have so far been unable to rectify. The config was copied visually across to the new firewall from the old so the majority of the config matches the old firewall. I have attached the config.
1. VOIP Phones not conencting to ntp uk.pool.ntp.org - Our VOIP network is on its own vlan inside the network. The phones were able  to conenct to the ntp externally before the new firewall was inplace. I have tested numerous access rules but with no luck.
2. VPN - We have setup a site to site VPN between the new Firewall and a SonicWall. The SonicWALL is showing the following errors from our firewall
07/10/2013 12:38:24.192
Info
VPN IKE
Received IKE SA delete request
77.107.90.203, 500
164.40.213.246, 500
VPN Policy: New_VPN
6
Warning
VPN IKE
Received notify. NO_PROPOSAL_CHOSEN
77.107.90.203, 500
164.40.213.246, 500
7
07/10/2013 12:38:24.160
Info
VPN IKE
IKE Initiator: Start Quick Mode (Phase 2).
164.40.213.246, 500
77.107.90.203, 500
VPN Policy: New_VPN
3. Firewall rules for outside coming in do not allow pointing to the NAT object of a device we have to use the internal network object instead.
Any help would be much appreciated.
Many Thanks
James
0 Replies 0
