Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Silver
ASA 5520 A/S failover
Hi All,
I have two 5520 in A/S statefull failover, sw: 7.2(1). My problem is that the secondary node after some days or week takes over the resources and become active. It show that there was an interface check error, nut as I checked there was not. And also in the sh failover output Normal (Waiting)is showed nect to the monitored interface. The ASAa are connected to Catalyst3750 and ports are in portfast state, and one outside port connects to directly my border router's switch card (portfast enabled).
Please help me....
Thanks in advance.
1 REPLY
Re: ASA 5520 A/S failover
I can suggest to check on the switch port VLANs.The both interfaces should be in same VLAN.and check the fail over configurations again like VRRP IP ( is it valid IP in th subnet) and other settings.
Hope it might help.
Cheers
199
