Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5520 Activation Key Help
Hi All,
we recently installed a activaiton key for the Anyconnect License on our ASA 5520. We have a pair runnning, in Active/Standby mode, on IOS 8.0. The Activation/License was installed on the Primary ASA. Once installed the all failover configuration was removed, and we were left with 2 ASAs running in Active/Active mode. This cause haoc across the network. I would like to go back and recover and reinstall the old activation key. Is this possible?? If so how would I be able to achieve this. Or do I need to ontain a new license key. Ultimately I would like to get back to the stage before instlaling the Anyconnect License, where we had a 2 ASAs running in Active/Standby mode.
Thank you for your help and suggestions.
Cheers
Deena
oput put from sh activation-key detail and sh version
CH-ASA# sh act det
Serial Number:  JMX1101K2SU
Permanent Flash Activation Key: 0x370fc559 0x2476a024 0xccc355a4 0xacd81440 0x4110329d
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 150
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
Temporary Flash Activation Key: 0x29249e66 0x500f33dc 0xcd79274e 0x534c7c93 0x81bc53bc
Maximum VLANs                : 150
VPN-DES                      : Enabled
VPN-3DES-AES                 : Disabled
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 750
This is a time-based license that will expire in 27 day(s).
Running Activation Key: 0x29249e66 0x500f33dc 0xcd79274e 0x534c7c93 0x81bc53bc
Maximum VLANs                : 150
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 750
This platform has an ASA 5520 VPN Plus license.
The flash activation key is the SAME as the running key.
CH-ASA# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(5)
Device Manager Version 6.2(5)53
Compiled on Mon 02-Nov-09 21:22 by builders
System image file is "disk0:/asa805-k8.bin"
Config file at boot was "startup-config"
CH-ASA up 18 hours 30 mins
Hardware:   ASA5520-K8, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash AT49LW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
0: Ext: GigabitEthernet0/0  : address is 0019.0665.6dfc, irq 9
1: Ext: GigabitEthernet0/1  : address is 0019.0665.6dfd, irq 9
2: Ext: GigabitEthernet0/2  : address is 0019.0665.6dfe, irq 9
3: Ext: GigabitEthernet0/3  : address is 0019.0665.6dff, irq 9
4: Ext: Management0/0       : address is 0019.0665.6dfb, irq 11
5: Int: Internal-Data0/0    : address is 0000.0001.0002, irq 11
6: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 5
Maximum VLANs                : 150
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
VPN Peers                    : 750
WebVPN Peers                 : 750
Configuration register is 0x1
Configuration has not been modified since last system restart.
CH-ASA#
1 REPLY
Hall of Fame Super Silver
Re: ASA 5520 Activation Key Help
If you upgrade your ASA software to a bit more recent image first you can share the AnyConnect license (activation key) across both devices. Otherwise you would need to install a separate activation key on the second unit.
727
