ASA 5520 boots to rommon #0> and doesn't fully load w/o typing boot
Hi, had to do a password recovery but must have typed something incorrect. Our ASA5520 now only boots to rommon #0> and we have to type "boot" to get it to fully load. Software version asa804-k8.bin.
Tried to go back to factory default, but still only boots to the rommon #0. Thanks, Chris.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: ASA 5520 boots to rommon #0> and doesn't fully load w/o typi
Chris
Sounds like your config register has been set to the wrong value. To set it back to default
no config-register
save and then reload your ASA -
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c4.html#wp2121156
Jon
Chris
no config-register
Jon
Hi Jon,
Easy enough thank you for solving my problem. :)
5882
