ASA 5520 Firewall configuration Problem
I have an ASA 5520 placed between two different networks and have to provide interconnectivity between them. The ASA is placed between two Layer 3 switches. I had configured ASA as below:
interface GigabitEthernet0/0 //(Outside)
nameif Network-2
security-level 0
ip address 10.66.88.100 255.255.255.0
interface GigabitEthernet0/1 //(Inside)
nameif Network-1
security-level 100
ip address 10.68.1.7 255.255.255.0
global (Network-2) 1 10.66.0.0 netmask 255.255.0.0
nat (Network-1) 1 10.68.1.0 255.255.255.0 0 0
route Network-2 10.66.1.0 255.255.255.0 10.66.88.200 1
Note:
1.) Say the two different networks are 10.68.1.0 (network A) and 10.66.1.0 (network B)
2.) 10.66.88.200 is the next hop ip address of the layer3 switch at Network-B
I am able to ping all the systems in the two networks from the ASA.
I am unable to ping interface 10.66.88.100 from Network-A and Network B. How to resolve the problem?? Please guide?.
All helpful posts will be rated
Thanks in Advance
Sridhar
1 REPLY
Hall of Fame Super Blue
Re: ASA 5520 Firewall configuration Problem
To allow network B to ping the outside interface try adding this to config
asa(config)# icmp permit 10.66.1.0 255.255.255.0 outside
I don't believe that the ASA device allows you to ping an interface that is remote ie.
from the inside you can only ping the inside interface of the ASA,, you cannot ping the outside interface and vice-versa.
Jon
244
