ASA 5520 Gig Interface Config Issue
I am trying to configure a IP Address on a Cisco ASA 5520. After configuring the IP I do a show int ip brief and it shows my interface Up and Up the method is manual but it says my IP is unassigned. If I do a show run it shows the IP address assigned to the port. It is only on the show int ip brief it doesnt seem to be showing. My other interfaces that show up on the show int ip brief say method CONFIG and they show the IP's. I cannot ping the interface I am having problems with so i know it is not working. Please help!
1 ACCEPTED SOLUTION
Re: ASA 5520 Gig Interface Config Issue
The interface has no ''nameif'' enabled.
Configure the ''nameif'' command under the interface and try again.
Federico.
Joseph,
Is the ASA getting an IP from DHCP on that interface or static?
Can you post the following:
sh run int e0
sh int ip bri
Federico.
It is a static IP. The interface I am having a issue with is Gig0/1 one of the working interfaces is Gig0/3. I will give a printout for both..
interface Gigabitethernet0/3
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
interface Gigabitethernet0/1
security-level 100
ip address 10.1.25.17 255.255.255.0
YPG-ASA5520-1# show int ip brief
interface                         IP-Address        OK?     Method     Status     Protocol
GigabitEthernet0/0          6.7.0.13            YES     CONFIG     up          up
GigabitEthernet0/1          unassigned        YES     manual       up         up
GigabitEthernet0/2          unassigned        YES     unset      administratively down down
GigabitEthernet0/3          10.10.10.1         YES     CONFIG     up          up
Management0/0              192.168.1.1        YES    CONFIG     down      down
Federico.
that fixed it, thank you Frederico
2318
