Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5520 IP range block or Country IP block
hi,
i need help on ASA 5520 and i would like to block countries IP address from the attack, there is any way to block countries ip address or range ip address .
Rabih
2 ACCEPTED SOLUTIONS
Re: ASA 5520 IP range block or Country IP block
Here is the URL on how to check what IP Range the countries has:
http://www.find-ip-address.org/ip-country/
(NB: pls scroll down to the bottom of the page, choose the country and hit "Submit").
Hope that helps.
Community Member
You can get the country ip blocks from here:-http://www.countryipblocks.net/country-blocks/19/
And then you can implement ACL's to block traffic coming in from these subnet range's.
Puneet
Hope that helps.
Community Member
Can I allow just one country and kick the rest off the world out ? As the usa has over 50 .000 ip,s the list of deny will be huge
Community Member
Puneet
Community Member
I've created a script where
I've created a script where you chose an authority by selecting in a menu and it'll give you the configuration to drop into the ASA.
https://github.com/in-transit/regional-asa
You can block or allow a specific region if you want. I'll be upgrading it to do specific countries but now it does authorities like ARIN, RIPE, APNIC, etc.
10517
