Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA 5520 - moving inside port to 1gb SFP port
We have an ASA 5520 and it's inside interface is currently plugged into a fast ethernet port on a 3750.  I have just bought a 1gig SFP module and have copied the fast ethernet port config to the gigabit port, but the port seems to be flapping, can you thik of any reason why it might be doign this?
The port conf gi is this:
interface GigabitEthernet1/0/4
description Link to Inside ASA
switchport access vlan 2
1 REPLY
try removing the trunk config and make it as switchport mode access...
also make the port config as speed 1000 and duplex auto in switch end
In ASA end make it as speed 1000 and duplex full. The check if still the flapping happens....
476
