ASA-5520 Multiple-context - Mgmt Inteface problem...
I have the following issue with the management interface of an ASA5520 running version 7.0(7).
I'm currently using two contexts in transparent mode.
The management interface is currently assigned to the admin-context and is physically connected to a cat4500 switch in a management Vlan.
The issue is that I have intermitent communication with this IP address from the 4500 and I just can't explain what's going on, the IP address configured in the management port is not repeated in the vlan and the interface vlan in the 4500 is always UP.
This is the configuration I am using in ASA:
*****system space*****
firewall transparent
interface GigabitEthernet0/0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface Management0/0
speed 100
duplex full
admin-context admin
context admin
allocate-interface GigabitEthernet0/0
allocate-interface GigabitEthernet0/1
allocate-interface Management0/0
context VPN
allocate-interface GigabitEthernet0/2
allocate-interface GigabitEthernet0/3
****CONTEXT ADMIN******
nameif gestion
security-level 0
management-only
nameif inside
security-level 100
nameif outside
security-level 0
access-list 199 extended permit ip any any
mtu gestion 1500
mtu inside 1500
mtu outside 1500
ip address 10.8.129.254 255.255.255.0
arp timeout 14400
access-group 199 in interface gestion
access-group 100 in interface inside
access-group 101 in interface outside
route gestion 0.0.0.0 0.0.0.0 10.8.129.1 1
aaa authentication ssh console LOCAL
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 10.0.0.0 255.0.0.0 gestion
ssh timeout 5
ssh version 1
dhcpd lease 3600
dhcpd ping_timeout 50
As I explained it is possible to log into the ASA using SSH but the connection is dropped at some point. I also need to upgrade the software version but the tftp session is dropped due to lack of conectivity.
Does anybody have a clue regarding the possible solution?
Many thanks
1 REPLY
Silver
Re: ASA-5520 Multiple-context - Mgmt Inteface problem...
The adaptive security appliance has a dedicated interface for device management that is referred to as the Management0/0 port. The Management0/0 port is a Fast Ethernet interface. This port is similar to the Console port, but the Management0/0 port only accepts incoming traffic to the adaptive security appliance.You can configure any interface to be a management-only interface using the management-only command. You can also disable management-only mode on the management interface. For more information about this command, see the management-only command in the Cisco Security Appliance Command Reference prsent in the link below:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/intparam.html#wp1051819
refer the link below for troubleshooting guide:
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/trouble.html#wp1042019
414
