Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 5520 not passing full interface rate traffic, or anywhere near
I have an issue where our ASA 5520 is impacting upload (from LAN to internet) speed.
We have a 100Mbps SDSL internet link and only see around 45-50 Mbps on the upload when going via the firewall, download is around 90+ Mbps so that is acceptable.
I have tested a laptop connected directly to the internet router and that give near on the 100Mbps up and down speeds, but if I put that laptop on the LAN or directly onto the firewall interface I only see 90Mbps down and 45Mbps up.
I have check that the interface speeds/duplex on the firewall, switch and laptop are correct and also checked there are no errors on the ports.
I also turned off the IPS and that made no difference.
In addition I have checked the CPU during download/upload (max):
CPU utilization for 5 seconds = 9%; 1 minute: 3%; 5 minutes: 1%
In theory the 5520 should be able to cope with this throughput:
Cisco ASA 5500 Series Model/License:    5520
Maximum firewall throughput (Mbps):          450 Mbps
Maximum firewall connections:                      280,000
Maximum firewall:                                               12,000
Packets per second (64 byte):                       320,000
Can any explain why this is the case?
I cannot see a physical issue, so it seems as though there is a config issue. I haven't changed any system parameters that would effect this, so d I need to tune the ASA?
Version: 8.2(4)
Hardware: ASA5520-K8, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz Internal ATA Compact Flash, 256MB
IPS Module ASA-SSM-20 (Ver 7.0(4)E4)
I have a variety of services running on/through this firewall:
Interface: Private/Public/DMZ/MPLS
VPN: SSL/Cisco-client/S2S
Standard firewall rules & NAT'ing
1 REPLY
Re: ASA 5520 not passing full interface rate traffic, or anywher
These two guides may help in finding the problem.
https://supportforums.cisco.com/docs/DOC-8982
https://supportforums.cisco.com/docs/DOC-12439
Don't forget to rate posts that are helpful.
1004
