Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
asa 5520 want to allow SMPT from inside to outside???
Can someone please give me an idea how to do this
, I have a program inside that needs to email me reports.inside address 172.16.1.20 to am SMTP on the internet.
Re: asa 5520 want to allow SMPT from inside to outside???
If you do not have an access-list on the inside interface, then it will be
automatically allowed. In order to check if there is an access-list applied
to the inside interface, issue the following command:
sh run access-group
If you see something like "access-group 25
Hope this helps.
NT
Community Member
I only have an access_outside group what would be the entry to m
ake the inside to out access group?
That access_outside group is probably applied on the outside interface.  So, there is no ACL applied on the inside interface.  Like Nagaraja said it will be automatically allowed. No need to do anything.
-KS
194
