ASA 5520 with overruns and underruns but low CPU
ASA has 3 interfaces: outside, inside, DMZ
Average total throughput is between 20-200mbps. Majority of throughput would be between inside and DMZ interfaces. CPU never goes above 70% (and doesn't seem to spike much with respect to traffic patterns).
We are seeing lots of errors on the interface. Inside output:
Interface GigabitEthernet0/1 "Inside", is up, line protocol is up
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
        Input flow control is unsupported, output flow control is unsupported
        Description: Inside LAN interface
        9097466566 packets input, 6650618441463 bytes, 0 no buffer
        Received 449 broadcasts, 0 runts, 0 giants
        75942 input errors, 0 CRC, 0 frame, 75942 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        9251999409 packets output, 3811434498126 bytes, 85579 underruns
        0 pause output, 0 resume output
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (255/230)
        output queue (blocks free curr/low): hardware (255/0)
The ASA is a VPN headend for 3 remote branches. Approximately 100 VOIP phones between the sites register to a phone server at the main site (where 5520 is).
I'm baffled by these overruns and underruns.
Code version 8.2(2).
I refuse to believe that I need to upgrade the firewall when a 5520 can supposedly process 450mbps (aware this is best case but our average is close to 80-100mbps) and should do 300,000 bps wheras on average we are pushing 10-15,000.
Is there anything we can do to find out why the ASA is having such a hard time processing all of the packets we are sending it?
Thanks guys!
Re: ASA 5520 with overruns and underruns but low CPU
you can try follwing. "show asp drop"
command refercence:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s2.html#wp1391007
PIX/ASA: Monitor and Troubleshoot Performance Issues
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml
Patrick
Message was edited by: Patrick Marc Preuss
Thanks for the reply. Output is shown below. This morning we had some terrible voice quality between HO and a branch site and there was no related CPU or interface bps spike during this time. Although we did see ASA inside interface errors/drops at the time. So not sure why this is happening.
Frame drop:
  Invalid encapsulation (invalid-encap)                                  1953077
  Invalid IP length (invalid-ip-length)                                     1256
  Invalid TCP Length (invalid-tcp-hdr-length)                                  5
  Invalid UDP Length (invalid-udp-length)                                      4
  No valid adjacency (no-adjacency)                                        35369
  Flow is denied by configured rule (acl-drop)                          18776203
  Invalid SPI (np-sp-invalid-spi)                                           6188
  NAT-T keepalive message (natt-keepalive)                                852142
  First TCP packet not SYN (tcp-not-syn)                                 2572558
  Bad TCP flags (bad-tcp-flags)                                             5752
  TCP Dual open denied (tcp-dual-open)                                     36688
  TCP data send after FIN (tcp-data-past-fin)                                476
  TCP failed 3 way handshake (tcp-3whs-failed)                           2184310
  TCP RST/FIN out of order (tcp-rstfin-ooo)                              2587928
  TCP SEQ in SYN/SYNACK invalid (tcp-seq-syn-diff)                          2280
  TCP SYNACK on established conn (tcp-synack-ooo)                            196
  TCP packet SEQ past window (tcp-seq-past-win)                            61410
  TCP invalid ACK (tcp-invalid-ack)                                         2626
  TCP replicated flow pak drop (tcp-fo-drop)                                  43
  TCP ACK in 3 way handshake invalid (tcp-discarded-ooo)                       3
  TCP Out-of-Order packet buffer full (tcp-buffer-full)                   152769
  TCP global Out-of-Order packet buffer full (tcp-global-buffer-full)          3
  TCP Out-of-Order packet buffer timeout (tcp-buffer-timeout)              68013
  TCP RST/SYN in window (tcp-rst-syn-in-win)                               23879
  TCP dup of packet in Out-of-Order queue (tcp-dup-in-queue)              432750
  TCP packet failed PAWS test (tcp-paws-fail)                             391464
  CTM returned error (ctm-error)                                               2
  IPSEC tunnel is down (ipsec-tun-down)                                     3799
  Slowpath security checks failed (sp-security-failed)                     55047
  Expired flow (flow-expired)                                                  1
  ICMP Inspect seq num not matched (inspect-icmp-seq-num-not-matched)         19
  ICMP Error Inspect no existing conn (inspect-icmp-error-no-existing-conn)  239
  DNS Inspect invalid domain label (inspect-dns-invalid-domain-label)        565
  DNS Inspect packet too long (inspect-dns-pak-too-long)                     366
  DNS Inspect id not matched (inspect-dns-id-not-matched)                   1248
  FP L2 rule drop (l2_acl)                                               6460539
  Interface is down (interface-down)                                          26
  Dropped pending packets in a closed socket (np-socket-closed)             4639
Last clearing: Never
Flow drop:
  NAT failed (nat-failed)                                                 241040
  NAT reverse path failed (nat-rpf-failed)                                  5820
  Tunnel being brought up or torn down (tunnel-pending)                       30
  Need to start IKE negotiation (need-ike)                                 63014
  Inspection failure (inspect-fail)                                        33182
  SSL handshake failed (ssl-handshake-failed)                                  3
  SSL malloc error (ssl-malloc-error)                                          2
  SSL received close alert (ssl-received-close-alert)                         12
  IPSec inner policy mismatch failure (ipsec-selector-failure)                 8
Hi Graham
is your installation new ?
what has changed rechently?
Have you configured qos?
What is the Traffic Pattern over this time?
What inspection is configured?
What say the log?
Can you clear the counters for this and place than again..
I see you have some drops due to tcp-buffers ...
Hi graham
have you tried the output interpreter
Interface Inside - GigabitEthernet0/1 (up/up)
  WARNING: There have been 85579 'underruns' reported.
  This indicates the number of times that the transmitter has been running faster
  than the ASA/PIX can handle.
  TRY THIS: Monitor the level of underruns over time. If they continue increasing,
  consider upgrading hardware. Also confirm that there is not a bad client network
  card or a virus on the segment causing traffic bursts. Use the show local-host
  ASA/PIX command to see if one IP is creating too many connections. Then, try
  the same command using the suspected ip to check the host’s activity.
  REFERENCE: For more information, see Troubleshooting Ethernet.
  WARNING: There have been 75942 'overruns' reported.
  This shows the number of times that the receiver hardware was incapable of handling
  received data to a hardware buffer because the input rate exceeded the receiver's
  capability to handle the data. If the overruns are equal to input errors and
  there are no CRC errors then at one point the ASA/PIX received packets faster
  than it can handle. This is not a cause of concern and can be ignored.
  TRY THIS: Verify that speed and duplex settings are hard-coded on the ASA/PIX
  and on the other directly connected devices. Use show blocks ASA/PIX command.
  A zero in the LOW column indicates a previous event where memory exhausted. A
  zero in the CNT column means memory is exhausted now. If the memory is continuously
  exhausted and traffic is not moving, then consider upgrading the interface to
  Gigabit or the ASA/PIX to a higher model. If this is DMZ interface, you can use
  other unused interfaces by splitting your current DMZ into 2 networks. If very
  large object-groups or large access-lists are used on ASA/PIX then use object-group-search
  keyword in the access-list ASA/PIX command to specify that access-list search
  is performed on object groups that are contained in access-list instead of searching
  the entire expanded access-list.
NOTE: Output Interpreter will perform analysis of ASA/PIX interface statistics
for all interfaces that are not administratively shutdown. Ensure that interface
statistics reflect the current state of the interfaces (<24hrs) by periodically clearing the
counters with the 'clear interface' command.
Hi Graham
is it possible for you to split the interfaces for inside?
2109
