ASA 5525-X IPS with Transparent Mode
Can I implement the new ASA 5525-X IPS in transparent mode? Can I still have fail open features with it? What are the pros and cons with this mode?
1 ACCEPTED SOLUTION
That for sure, no problem.
The IPS can sit inline
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Sure you can.
Regarding the IPS and Firewall there are no such restrictions.
Restrictions would be with the way the ASA behaves.
EX:
No  VPN support
No routing protocols.
Stuff like that buddy
Jcarvaja
So all I need to do is from the active firewall inside interface--> connect it to ASA IPS ----> L3 switch.
IPS will be active only when the primary firewall is active.
Do I need to allow any specific rules on IPS for the ASA HA pair to work when I insert IPS in between primary and the L3 switch?
Remember that the ASA 5500-X Family use a software based IPS. So no physical interface to connect but logicals.
Now, you are talking about fail-over between ASAs. Before was fail-open and fail-closed with the IPS itself.
The answer to the last question is yes, if the active ASA fails then the ASA will too. There will be a switchover.
No special rules, no worry. From the IPS perspective it will work the same.
Jcarvaja
Can I have ASA-IPS in inline mode with transparent mode as well?
Jcarvaja
201
