ASA 5540 8.4 and Voice Gateway (SIP)
have ASA  FW with 8.4(2) : inside is connected to lan , DMZ is  having SIP Gateway router , i have configured the Firewall will required  ports and enabled sip inspection under policy-map but no VOICE  traffic  is passing through the firewall ,  iam using static nat
there are ports opened from both side ASA (dmz-inside and other way)
object-group service TCP tcp
port-object eq sip
port-object range 2000 2443
port-object eq h323
port-object eq rtsp
port-object eq 5061
port-object eq 50693
port-object eq 16341
object-group service UDP udp
port-object eq sip
port-object range 16384 32767
port-object eq tftp
port-object eq ntp
port-object eq 1718
port-object eq 1719
port-object eq 5061
port-object eq 57280
Following is inspection
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect dns
service-policy global_policy global
phones are not getting registered .....how about the NAT it should be static between DMZ to inside or No NAT statement
any sugesstions would be helpfull
Silver
Although it is a document about ASA on another version it explains how SIP inspection works on the ASA. For you to understand this document you need to understand the device that you are configuring behind the ASA and how SIP works in general.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
Send a copy of the complete configuration and show service-policy
Value our effort and rate the assistance!
Silver
Do you still need assistance?
Please rate our assistance.
Silver
267
