ASA 5540 failover pair, upgrade question
We have an active / standby failover pair of ASA 5540 running 8.2 version in a production environment.
We have a task of upgrading ASA software to version 8.4.
We're quite familiar with the process of upgrading and looked through zero downtime manuals available.
The only question is what should we do with NAT, which should be completely rewritten according to 8.3 syntax.
Is it possible to upgrade like this:
- upgrade ios of the standby unit
- change NAT statements on a freshly upgraded standby ASA
- make that ASA with 8.3 active
- upgrade the second ASA
Thanks in advance.
VIP Green
Yes this is possible but the 8.2 version will need to be the last minor release version.
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/admin_swconfig.html#wp1380398
-- Please remember to rate and select a correct answer
You don't have to do anything with NAT as it will be automatically converted from 8.2 NAT configuration into the new syntax.
Mariusz
Thank you both.
I'm a little bit afraid of automatic nat convertion - does it really work well and there is nothing to worry about?
Thank you.
161
