Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5540 - VLAN Subinterfaces and Routing
We are testing the use of layer 3 switching, trunking, and VLAN subinterfaces with the (4) INSIDE networks. Layer 2 and Layer 3 pings are working at the switch, however from the subinterfaces on the firewall they can only see their subnet.
Pinging from systems on the subnets can see their subnets but not the others.
IP routes show connected on both the switch and firewall. Only INSIDE subnet is getting out to the OUTSIDE interface, the other 3 are isolated for some reason.
FIREWALL ROUTES:
Gateway of last resort is xx.xx.61.1 to network 0.0.0.0
C    xx.xx.61.0 255.255.255.0 is directly connected, OUTSIDE
C    172.16.1.0 255.255.255.0 is directly connected, DMZ
C    192.168.102.0 255.255.255.0 is directly connected, vmKERNEL
C    192.168.1.0 255.255.255.0 is directly connected, INSIDE
C    192.168.2.0 255.255.255.0 is directly connected, prodPS
C    192.168.101.0 255.255.255.0 is directly connected, vmCONSOLE
S*   0.0.0.0 0.0.0.0 [1/0] via xx.xx.61.1, OUTSIDE
SWITCH ROUTES:
Gateway of last resort is not set
C    192.168.102.0/24 is directly connected, Vlan202
C    192.168.254.0/24 is directly connected, Vlan911
C    192.168.1.0/24 is directly connected, Vlan101
C    192.168.2.0/24 is directly connected, Vlan102
C    192.168.101.0/24 is directly connected, Vlan201
We are getting portmap translation errors in reference to the other 3 INSIDE networks which all have the same security level of 100.
We have been looking at this too long, can't see the forest thru the trees.
Firewall Config:
interface GigabitEthernet0/0
description OUTSIDE - VLAN 666
speed 100
duplex full
nameif OUTSIDE
security-level 0
ip address xx.xx.61.226 255.255.255.0
interface GigabitEthernet0/1
speed 100
duplex full
no nameif
security-level 100
no ip address
interface GigabitEthernet0/1.101
description PROD-RS - VLAN 101
vlan 101
nameif PROD-RS
security-level 100
interface GigabitEthernet0/1.102
description PROD-PS - VLAN 102
vlan 102
nameif PROD-PS
security-level 100
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/1.201
description VM-CONSOLE - VLAN 201
vlan 201
nameif VM-CONSOLE
security-level 100
ip address 192.168.101.1 255.255.255.0
interface GigabitEthernet0/1.202
description VM-KERNEL - VLAN 202
vlan 202
nameif VM-KERNEL
security-level 100
ip address 192.168.102.1 255.255.255.0
interface GigabitEthernet0/2
description DMZ - VLAN 411
speed 100
duplex full
nameif DMZ
security-level 25
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/3
speed 100
duplex full
no nameif
no security-level
no ip address
interface Management0/0
description MANAGE - VLAN 911
speed 100
duplex full
nameif MANAGE
security-level 100
ip address 192.168.254.1 255.255.255.0
boot system disk0:/asa821-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
name-server 192.168.1.30
domain-name PetiteSirens.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pager lines 24
logging enable
logging buffer-size 30000
logging buffered debugging
logging asdm notifications
mtu OUTSIDE 1500
mtu PROD-RS 1500
mtu DMZ 1500
mtu MANAGE 1500
mtu PROD-PS 1500
mtu VM-CONSOLE 1500
mtu VM-KERNEL 1500
ip verify reverse-path interface OUTSIDE
ip verify reverse-path interface DMZ
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
asdm history enable
arp timeout 14400
global (OUTSIDE) 101 interface
nat (PROD-RS) 101 0.0.0.0 0.0.0.0
nat (DMZ) 101 0.0.0.0 0.0.0.0
nat (MANAGE) 101 0.0.0.0 0.0.0.0
nat (PROD-PS) 101 0.0.0.0 0.0.0.0
route OUTSIDE 0.0.0.0 0.0.0.0 xx.xx.61.1 1
SWITCH config:
hostname aswitch01
no aaa new-model
clock timezone UTC -6
clock summer-time UTC recurring
switch 1 provision ws-c3750-24p
system mtu routing 1500
vtp domain INSIDE
vtp mode transparent
authentication mac-move permit
ip subnet-zero
ip routing
spanning-tree mode pvst
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 101
name PROD-RS
vlan 102
name PROD-PS
vlan 201
name VM-CONSOLE
vlan 202
name VM-KERNEL
vlan 911
name MANAGE
interface Loopback0
no ip address
interface FastEthernet1/0/1
switchport access vlan 101
switchport mode access
power inline never
speed 100
duplex full
no cdp enable
spanning-tree guard root
interface FastEthernet1/0/24
description TRUNK to FIREWALL INT G0/1
switchport trunk allowed vlan 101,102,201,202,911
switchport mode trunk
power inline never
speed 100
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan101
ip address 192.168.1.11 255.255.255.0
interface Vlan102
ip address 192.168.2.11 255.255.255.0
interface Vlan201
ip address 192.168.101.11 255.255.255.0
interface Vlan202
ip address 192.168.102.11 255.255.255.0
interface Vlan911
ip address 192.168.254.11 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip http server
ip http secure-server
Re: ASA 5540 - VLAN Subinterfaces and Routing
Hello Sdhill
  Topology          Internet
                           ASA
                             || Trunk
                      | L3 switch |
              Vlan101  Vlan102  Vlan103
I am assuming that the only interface is that is able to go out to the internet is PROD-RS - VLAN 101 is that correct? Well this actually makes sense and let me explain you why.
Lets say that you are sitting on the vlan PROD-PS - VLAN 102, this are the steps (based on your routing) on how a packet would flow when going to the outside:
-It is going to go from the computer to the Layer 3 switch
-From the layer 3 switch its going to pick up the default route which poing to 192.168.1.1 and head the the PROD-RS - VLAN 101 interface of the Firewall
-Then the return packet from the outside comes to the firewall with a destination that is directly connected to it and it is going to try to send it to PROD-PS - VLAN 102
-The problem is that the firewall already has an state entry that says that the packet first went out throuh the interface PROD-RS - VLAN 101, and then since it is not the same interface as it was when it went out, the packet will be discarded. (Because of asymmetric routing)
Nature rule of every Stateful Firewall, if packet goes out on one interface, the return packet should be send on the same one.
But, why does it work with the Vlan 101?
The packet enters and leaves on the same interface, opposite on what happens when you start a connection on Vlan 102, or any other vlan.
I am pretty sure that if you change the default route on the switch to be 192.168.2.1, everyone on that vlan will be able to access the outside interface but Vlan 101 and the rest would be blocked.
How to solve this?
If you want to protect your Network on an effective way, I would recommend you to have the routing being done only on the firewall, thus disabling routing capabilities on the switch and leaving only the l2 Vlan segmentation.
If you have any doubts, please let me know, I would be more than glad to assist.
Mike
Mike
Community Member
Howdy Maykol,
I disagree slightly with your trace since all 4 subnets are trunked to the firewall using VLAN subinterfaces. The gateway of last resort is the OUTSIDE interfaces' peer at the ISP. Each VLAN is designated on the firewall have their own gateways.
The ip default-gateway actually doesn't apply in the switch configuration (even though it is defined) since Layer 3 routing is enabled and the gateway of last resort is defined on the firewall.
We tried disabling ip routing on the switch but the results were not much better.
If we went to layer 2, then we would have to remove the subinterfaces and VLANs from the firewall, remove the trunk, and implement a Layer 3 switchport on the switch then define static routes on the firewall -seems to be the best practice recommendation.
Not sure which is more effective or best practice.
Things to consider, in the future we have to implement VPN access that has issues with hairpins. Trying to keep things more flexible without excessive manipulation of the NATs (static) especially before upgrading to v8.3.
I think my issue is more about NAT since they are dynamic and not static since we only get portmap translation issues on the firewall for VLANs 102, 201, and 202.
Scott
4153
