ASA 5550 and ASDM
I hav ASA 5550 with 9.1(2) IOS and ASDM 7.1
The problem is connecting to this asa with asdm and connecting to https. I tried every thing I know.
I downgreadet java and tripple checked my configuration and even erased the whole configuration and re started.
I set this things
Host name
Domain name
user name and password
password enable
the interface
http server enable
http ip addres that can access it
clock
ssh ip address that can access it (which works using the same ip addres as for the http)
When I start the asdm and click connect then see the java debug on the asdm. I see that there is a critical error handshake failed and connection lost.
I can ping the asa and connect via ssh.
the firewall works great but I cant acces https of connect to it using the asdm. I have another asa 5510 with the same ios and asdm that I configure exacly the same and the asdm works.
ASA 5550 and ASDM
I understand you have working 5510, but can you cross check with the below config (security level does not matter).
https://supportforums.cisco.com/docs/DOC-24877
Thx
MS
ASA 5550 and ASDM
Hi Tomaz,
Could you please double-check if you have the 3DES license; if you do issue the command sh run all ssl; you should see a large list of hash/encryption algorithm. If you just see a few issue the command clear config ssl
HTH,
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach us"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva "If you need PDI (Planning, Design, Implement) assistance feel free to reach us" http://www.cisco.com/web/partners/tools/pdihd.html
Hall of Fame Super Silver
ASA 5550 and ASDM
Luis's suggestions are on the mark. I would look for check your 3DES-AES license and then look for ssl lines in the configuration to include strong encryption algorithms. Newer ASAs have been shipping without that enabled by default - e.g., "ssl encryption aes256-sha1 aes128-sha1"
ASA 5550 and ASDM
Ok I checked for 3DES-AES and it is on.
I checked with the config and its correctly configured.
Yes I have opened the network with http command.
I was so fristrated that I went and downgraded my asa from 9.1(2) to 8.0(4) with the curent running config after the downgrade the asdm works like a charm. and I can open the https.
I will have to take my time and de bug this asa and IOS for bugs.
Thx for all of your help.
Tomaz
ASA 5550 and ASDM
Hi Thomaz,
Post the related part to this issue of your asa config man.
That can be many things.
From the network that you are trying to access ASA you can ping it?
Do you have opened the network with hhtp command to access the asa?
Ex: http 192.168.10.0 255.255.255.0 inside
AS
290
