ASA 5580 local-host problem
We have 2 border routers (7609-S) running BGP routing protocol with 3 different ISPs and are connecting to 2 ASA5580-40 firewalls (Active-standby mode).
A server X on Interent is connecting to our server Y in LAN. Server X is unable to connect to server Y if any of the 3 ISP links got interrupted. Even link is recovered but X still failed to connection to Y everytime.
We found that didn't find any IPINIP connection when I do " show local-host x.x.x.x(IP of X) on ASA firewall:
(IP of X & Y are shown as x.x.x.x and y.y.y.y for confidentiality)
FW01# sh local-host x.x.x.x
Interface Inside: 1554344 active, 1610150 maximum active, 0 denied
Interface Outside: 1040329 active, 1465152 maximum active, 0 denied
local host: <x.x.x.x>,
    TCP flow count/limit = 0/unlimited
    TCP embryonic count to host = 0
    TCP intercept watermark = unlimited
    UDP flow count/limit = 1/unlimited
  Conn:
    UDP Outside x.x.x.x:434 Outside y.y.y.y:434, idle 0:00:00, bytes 3310318788, flags -
Interface Stateful: 1 active, 2 maximum active, 0 denied
Interface management: 1 active, 4 maximum active, 0 denied
Interface Failover: 1 active, 2 maximum active, 0 denied
Once I issue "clear local-host x.x.x.x", the connection is up:
FW01# clear local-host x.x.x.x
Interface Inside: 1554451 active, 1610150 maximum active, 0 denied
Interface Outside: 1039506 active, 1465152 maximum active, 0 denied
  Conn:
    IPINIP Outside x.x.x.x Inside y.y.y.y, idle 0:00:00, bytes 3440
    UDP Outside x.x.x.x:434 Inside y.y.y.y:434, idle 0:00:00, bytes 2156, flags -
    IPINIP Outside x.x.x.x Inside y.y.y.y, idle 0:00:00, bytes 2784
We have workaround to do clear local-host everytime now but are still finding solution on it. Could anyone adivce on it please? thanks in advance.
1 ACCEPTED SOLUTION
Hello; This specifies UDP
Hello;
This specifies UDP (typo on the document or whatever) but you can use the "timeout-floating-conn".
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113592-udp-traffic-fails-00.html
It will kill the connection that is floating on an non existing interface instead of waiting for the whole hour or to manually clear the conn.
Mike.
Mike
1 REPLY
Hello;
Mike.
Mike
95
