Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 5585 Maximum number of connections
I have a 5585 ASA firewall, how could I see to the maximum number of session.
thank you!
1 REPLY
Hi,You can check that using
You can check that using the below mentioned commands
sh conn --> this will show the active connection that is running through the firewall with flag details....
show resource usage all ==> This will show just the count of connections present, peak and max limit and dropped.....
Karthik
56
