ASA 5585 Maximum number of connections
I have a 5585 ASA firewall, how could I see to the maximum number of session.
thank you!
1 ACCEPTED SOLUTION
Super Bronze
Hi, You can check the maximum
You can check the maximum connection limit depending on the hardware/model used from the following document.
http://www.cisco.com/c/dam/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/prod_brochure0900aecd80285492.pdf
On the ASA CLI you can check the current connection amount on the firewall with the command
show conn count
You should also be able to see the devices current connections and the maximum limit with the command
show resource usage summary
or
show resource usage resource conns
Please do remember to mark an answer as the correct reply if it answered your question. Feel free to ask more if needed.
Hope this helps :)
- Jouni
Super Bronze
show conn count
or
Hope this helps :)
- Jouni
I will try on the ASA 5585,
I will try on the ASA 5585, Thank you for the first.
1178
