Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 55xx issue
I'm having issues with a new ASA implementation. I have some direct one-to-one translations specificed and I want all the rest of my outbound traffic to go out the global PAT address, but for some reason, all traffic, including inside hosts with outside NATs are appearing as the global PAT address.
Config attached
1 ACCEPTED SOLUTION
Green
Re: ASA 55xx issue
Your statics are backwards. Should be...
static (inside,outside) 208.xxx.xxx.163 192.168.1.220 netmask 255.255.255.255
Green
Re: ASA 55xx issue
Community Member
Re: ASA 55xx issue
OMG! Sleep deprivation is not good, people! Thanks, acomiskey!
This setup is a conversion from an IP Chains linux firewall and I realize what I did. While documenting the static mappings I used Excel to create my internal and external columns. I then concatenated everything into the cisco static command format and switched my internal and external columns around.
Thanks again!
Randy
120
