ASA-6-110002: Failed to locate egress interface for ICMP from vlan
Following is my config on 5525-X firewall,
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.100
vlan 100
nameif vlan100
security-level 100
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/1.200
vlan 200
nameif vlan200
security-level 100
ip address 10.10.20.1 255.255.255.0
PC with IP address 10.10.10.12 tries to ping 10.10.20.1,  I am getting the following error
%ASA-6-110002: Failed to locate egress interface for ICMP from vlan100:10.10.10.12/1 to 10.10.20.1/0
From the ASA itself I can ping both interfaces. But extended ping from vlan 100 to vlan 200 fails with the above error as well.
1 ACCEPTED SOLUTION
Super Bronze
You wont be able to ICMP the far end interface from behind another interface. What I mean is that users behind Vlan100 can only ICMP Vlan100 interface IP address and users behind Vlan200 can only ICMP Vlan200 interface IP address on the ASA. They wont be able to ICMP any other interface IP address. This is basic behaviour for the Cisco firewalls for a long time. Though I am not sure what the purpose is.
If you want to have traffic flowing between these 2 interfaces and their networks you would have to also check that you have this configured
same-security-traffic permit inter-interface
This would allow traffic between 2 different interfaces using the same "security-level" value which you seem to have. Without the above command the traffic wont be allowed through even if you have ACLs allowing the traffic.
- Jouni
1 REPLY
Super Bronze
- Jouni
3754
