Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
%ASA-6-110003: Routing failed to locate next hop for UDP
I am experiencing the below error in ASA2 logs.
%ASA-6-110003: Routing failed to locate next hop for UDP from outside-ASA:GLOBALDNS/53 to inside-ASA:20.1.1.10/32999
- ASA2 (Management Interace: 20.1.1.0/24)
Traffic Flow:
ASA2 (Management Interface) -> Cat65K SVI10 (which has route-map policy to go out via ASA2 (Inside Interface) -> Routed to Cat65K SVI11 -> ASA2 (Inside Interface) -> Source IP overloaded on ASA2 outside interface -> Source IP overloaded again on ASA1 on outside/internet interface -> Return Traffic to ASA1 outside interface -> Return traffic hits ASA2 and the error in subject gets logged.
Please assist.
1 REPLY
Re: %ASA-6-110003: Routing failed to locate next hop for UDP
It seems NAT issue...
1561
