ASA 7.2.2 - Problems VPNs Remote Access
HI,
I?m trying to configure VPNs Remote Access in a ASA 7.2.2. However, they doesn?t work, so can anybody tell me, the following topics:
What commands can I use to do thoubleshooting?. I use "debug crypto ipsec", "debug crypto sa",...but I don?t see nothing in ASA.
- The subnet used by the remote clients has to be an internal network. So, have I to route this subnet towards inside?. I have serveral internal networks, and the ASA Interface inside is in a different subnet internal.
Is there any good sample document about these topics?
Thank you very much
Best Regards
Re: ASA 7.2.2 - Problems VPNs Remote Access
This link describes how to turn your ASA into a VPN server using ASDM:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
Also, you stated that nothing showed up on the debugs, that leads me to believe that the udp 500/4500 (IKE) traffic is not making it to the ASA (ISP issue) ir that you dont have isakmp and/or a crypto map applied to the outside interface.
Please let me know if this helps.
Bryan
You might also check your NATing. Make sure the remote subnets are either NATed to something you route or you have a NO NAT statement that allows them to remain intact on your network.
Ok, thank you very much.
I have done like it appears in the document, and the vpn works well. However, I have an important problem.
When the vpn client is connected, the ASA (it seems), that block all tcp connections between, from inside to outside.
Have you any times a similar problem?.
Thank you very much.
Best Regards.
Nuria
Therre are some good documents online. I have one set up with an ASA running 7.2.1. The pool resides onthe ASA and is routed to it so the replies reture to it. Are you using the normal cisco vpn client?
Marty Barron
Looks like this
inet ->asa -->in<-- route to vpn addresses
Did you turn on "logging monitored" ? Also take a look at Document ID: 70330, should solve your problem.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806de37e.shtml
post your config
use command sysopt ipsec permit
that way vpn traffic will not be inspected
182
