ASA 8.0(2) do not have traffic shape feature?
Hi there,
Recently I want to apply traffic shape on my ASA5520, but after entering the configure mode of policy-map, I couldnot find the shape command.. If I type the command, the device would notify me that there is no such command..
My version is 8.0(2), does anyone of you have idea about this?
PS. Police command is working fine...
Thanks in advance.
Best regards,
Victor
  • Firewalling
I used my favorite search engine and used the text "cisco asa 8.0.(2) configuration guide"
The fourth link was http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/fwmode.html
The 8th chapter down "Applying QoS Policies"
Under "Configuring QoS"
     "Configuring a Service Rule for Traffic Shaping and Hierarchical Priority Queuing"
It took me 2 mins to find this.
HTH>
Thanks Andrew,
But how to configure traffic shape is not my problem. My problem is that in my ASA5520, the command 'shape' is 'Unreconginazed command'...
Best regards,
Victor
So you followed the configuration steps in the document - like below
Step 1
policy-map name
Example:
hostname(config)# policy-map shape_policy
Adds or edits a policy map. This policy map must be different from the hierarchical priority-queuing map.
Step 2
class class-default
Example:
hostname(config-pmap)# class class-default
Identifies all traffic for traffic shaping; you can only use the class-default class map, which is defined as match any, because the security appliance requires all traffic to be matched for traffic shaping.
Step 3
shape average rate [burst_size]
Example:
hostname(config-pmap-c)# shape average
70000 4000
Yes, I followed the guide exactly...
OK - post the config and any errors you are seeing?
557
