Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 8.2(1) Routing between contexts
Hello
I have an ASA with to contexts which share two interfaces (see attached graphic). Both contexts run on the same 5540
I want to ssh Context B firewall from the Intranet, but it doesn't work.
IP Routers are ok.
I have configured access-lists on Context A, an they're matched.
A Capture shows that traffic gets to the inside interface of Context A, but it doen't show anything on the interface shared with context B.
I can ping from context A to Context B but Context B MAC address is not shown in Context A (neither on the other way).
From 192.168.5.0/0 netwok I can see both context's MACs an ssh both of them
If both contexts run on the same hardware. How is traffic routed between contexts? Is there a kind of virtual interface??
capture captura type raw-data access-list captura interface redfw1 [Capturing - 656 bytes]
capture captura2 type raw-data access-list captura interface inside1 [Capturing - 0 bytes]
show capture captura
   1: 10:05:52.500889 802.1Q vlan#207 P0 10.240.1.1.1546 > 192.168.5.252.22: S 3701265995:3701265995(0) win 65535 <mss 1380,nop,nop,sackOK>
   2: 10:05:55.447944 802.1Q vlan#207 P0 10.240.1.1.1546 > 192.168.5.252.22: S 3701265995:3701265995(0) win 65535 <mss 1380,nop,nop,sackOK>
   3: 10:06:01.463568 802.1Q vlan#207 P0 10.240.1.1.1546 > 192.168.5.252.22: S 3701265995:3701265995(0) win 65535 <mss 1380,nop,nop,sackOK>
   4: 10:06:13.495152 802.1Q vlan#207 P0 10.240.1.1.1546 > 192.168.5.252.22: S 2126103373:2126103373(0) win 65535 <mss 1380,nop,nop,sackOK>
   5: 10:07:11.963176 802.1Q vlan#207 P0 10.240.1.1.1670 > 192.168.5.252.22: S 1470710979:1470710979(0) win 65535 <mss 1380,nop,nop,sackOK>
   6: 10:07:14.931470 802.1Q vlan#207 P0 10.240.1.1.1670 > 192.168.5.252.22: S 1470710979:1470710979(0) win 65535 <mss 1380,nop,nop,sackOK>
   7: 10:07:20.947109 802.1Q vlan#207 P0 10.240.1.1.1670 > 192.168.5.252.22: S 1470710979:1470710979(0) win 65535 <mss 1380,nop,nop,sackOK>
   8: 10:07:32.979334 802.1Q vlan#207 P0 10.240.1.1.1670 > 192.168.5.252.22: S 149075897:149075897(0) win 65535 <mss 1380,nop,nop,sackOK>
show capture captura2
0 packet captured
0 packet shown
THANK YOU IN ADVANCE
Everyone's tags (3)
1 REPLY
Re: ASA 8.2(1) Routing between contexts
It works. It was a matter of statics
1902
