ASA 8.2 Twice NAT Problem
I have a production scenario where I need to implement twice NAT in my ASA(8.2(5)). I cannot upgrade this Firewall as of now.
The Topology goes like this,
 (172.16.0.0/12)SPOKE---->(OUTSIDE)ASA(INTERNAL)---->3rdPARTY FW(172.23.102.92)
1. Requirement is, the Spoke Location users should access Webserver 172.23.102.92 via IP:172.25.1.42(This IP is advertised over WAN)
2. Now my 3rd Party wants to NAT my Source Traffic(172.16.0.0/12) to 10.100.43.0/24 and send it.
I have done the following config and its not working.
access-list SPOKE-NAT extended permit ip 172.16.0.0 255.240.0.0 ho 172.25.1.42
nat (OUTSIDE) 2 access-list SPOKE-NAT
global (INTERNAL) 2 10.100.43.0 netmask 255.255.255.0
access-list P3NAT permit ip ho 172.23.102.92 10.100.43.0 255.255.255.0
static (INTERNAL,OUTSIDE) 172.25.1.42 access-list P3NAT
Upon using Packet Tracer , it says "translating to dynamic pool 2 (no matching global)"
Super Bronze
Hi, Can you post the complete
Can you post the complete output of the "packet-tracer" command and the actual command used.
Do you mean that you want to use a NAT Pool in this case? If so you should have something like
global (INTERNAL) 2 10.100.43.1-10.100.43.253
global (INTERNAL) 2 10.100.43.254
- Jouni
Packet Trace Logs : packet
Packet Trace Logs : packet-tracer input MPLS-ZONE tcp 172.22.1.1 80 172.25.1.42 80 det
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
 Forward Flow based lookup yields rule:
 in  id=0x928ae750, priority=12, domain=capture, deny=false
        hits=7342021, user_data=0x92afd1f0, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
 in  id=0x91cc2ba0, priority=1, domain=permit, deny=false
        hits=511378318, user_data=0x0, cs_id=0x0, l3_type=0x8
        dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match ip INTERNAL host 172.23.102.92 OUTSIDE 10.100.43.0 255.255.255.0
    static translation to 172.25.1.42
    translate_hits = 0, untranslate_hits = 25
NAT divert to egress interface INTERNAL
Untranslate 172.25.1.42/0 to 172.23.102.92/0 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group OUTSIDE in interface OUTSIDE
access-list OUTSIDE extended permit ip any any
 in  id=0x91edba68, priority=12, domain=permit, deny=false
        hits=28433851, user_data=0x8e9fc000, cs_id=0x0, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x91cc5018, priority=0, domain=inspect-ip-options, deny=true
        hits=58261256, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
 in  id=0x91cbbb48, priority=21, domain=lu, deny=true
        hits=4473467, user_data=0x0, cs_id=0x0, flags=0x0, protocol=6
        dst ip=0.0.0.0, mask=0.0.0.0, port=80, dscp=0x0
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip OUTSIDE 172.16.0.0 255.240.0.0 OUTSIDE host 172.25.1.42
    dynamic translation to pool 2 (No matching global)
    translate_hits = 0, untranslate_hits = 0
 in  id=0x92cd1e08, priority=2, domain=host, deny=false
        hits=23362, user_data=0x926a5c18, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=172.16.0.0, mask=255.240.0.0, port=0
Phase: 8
Type: NAT
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
 in  id=0x926b2b30, priority=5, domain=host, deny=false
        hits=41, user_data=0x92b01db0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=172.23.102.92, mask=255.255.255.255, port=0
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0x929d89d0, priority=0, domain=inspect-ip-options, deny=true
        hits=2515, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 94023450, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: OUTSIDE
input-status: up
input-line-status: up
output-interface: INTERNAL
output-status: up
output-line-status: up
Action: allow
Anyone who could help me out
Anyone who could help me out here !!!!
109
