Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 8.25 upgrade to 9.14 problem
We have just upgraded our ASA 5510 from 8.25 to 9.14 via 8.47 using ASDM and everything seemed to be working.
However we have an external program that accesses a server in our DMZ that has stopped and we just cant see the issue.
Without copying in our entire asa config, is there anything obvious that anyone can think of that could be causing the issues. We have been looking at the NAT and access rules and trying to work out how it has changed.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: ASA 8.25 upgrade to 9.14 problem
The first things that spring to mind is og course NAT and ACL. Maybe check the arp that are registred to the dmz interface. Also run a "show xlate" and check for the dmz server address.
Are there no connection ? ICMP (ping) ?
Hsve you run the packet tracer, either from asdm CLI ?
Please rate as helpful, if that would be the case. Thanx
PRovide the output you will get from
packet-tracer input outside tcp x.x.x.x (host on the outside that connects)  1025 y.y.y.y (public address of server) # (port where it listens)
Example
packet-tracer input outside tcp 4.2.2.2 1025 8.8.8.8 80
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
In case anyone has the same issue.
Our managed Internet provider had to make a few simple route changes to their firewall.
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113577-ptn-113577.html
710
