11-24-2010 02:33 AM - edited 03-11-2019 12:13 PM
Hello everyone,
I have a customer with a ASA 8.3 version. The customer wants to make pat from the public ASA IP to several internal IP address in the inside interface (diferent ports).
something like, everyone who telnet to port 50030 on public ASA IP is send to port 80 in a private IP address.
I configure the ASA this way:
object network Webserver
host 192.168.100.100
nat (inside,outside) static interface service tcp 80 50030
access-list outside_access_in extended permit tcp any object Webserver eq 50030
access-group outside_access_in in interface outside
When I type the command «show xlate» I have this result:
show xlate | inc 192.168.100.100
12-02-2010 07:39 AM
This is the first entry of my access-list that is applied to outside interface (access-group outside_access_in in interface outside):
access-list outside_access_in line 1 extended permit tcp any host 194.38.X.X eq 50030 (hitcnt=0)
The packets appear at show capture but don´t hit the entry at access-list. WHY ??????????????
12-02-2010 07:45 AM
They don't hit your ACL entry because you are referencing public IP and you must reference real IP.
Regards.
12-02-2010 07:51 AM
Hello Cadetalain,
It´s not that because I have all this entrys in access-list:
access-list outside_access_in extended permit tcp any host 194.38.X.X eq 50030
access-list outside_access_in extended permit tcp host 213.58.X.X any eq www - IP 213.58.X.X is the IP of the router from where I´m testing telnet to port
access-list outside_access_in extended permit tcp host 213.58.X.X any eq 50030
access-list outside_access_in extended permit tcp any object Webserver eq www
the packet don´t hit any of this entrys
12-02-2010 08:19 AM
I put this entry at access-list (with the real private IP address) but is exacly the same (no hits):
access-list outside_access_in line 1 extended permit ip any host 192.168.100.100 (hitcnt=0)
12-02-2010 08:51 AM
Ok. This is very interesting. Could you pls. quickly open a TAC case and provide the case number here?
I will take a look.
on the capture command that I gave you, you can include the word "trace" in the end and issue "sh cap capout trace" and see where we are dropping the packet.
-KS
01-25-2011 08:05 AM
Hi Nelson,
I have the same Problem with ASA 8.3.2.
Do you have a resolutin yet from CCO ?
regards,
Herbert
05-07-2011 04:39 PM
Yeah..any answer for this problem yet?
05-08-2011 03:47 AM
Foo,
I am not sure if Nelson opened a TAC case or not. Whether this issue is resolved or not. We do need the output that I requested in the earlier thread - capture with the trace option.
-KS
05-08-2011 09:02 AM
that's too bad...as I think I'm hitting a similar issue (not exact, just similar) and I will look into it further before submitting a TAC.
05-08-2011 11:59 PM
I have found a solution for my problem:
since this NAT is a "Source-NAT" and the service object defaults to a destination service objects, I changed the configuration
of the service object like this:
object service obj-https-service
service tcp source eq https
(in CSM this looks like tcp/443/Default Range )
then the NAT is
nat (inside,outside) 1 source static obj-real interface service obj-https-service obj-https-service
regards,
Herbert
05-09-2011 01:42 AM
Glad to hear that. That is a very good point to note. But in this thread I believe it fails when specifically specifying the port number without using a service object.
-KS
