Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 8.4(2) NAT problem
I'm trying to implement NAT on ASA and I found very strange behavior.
a) I started with dynamic NAT:
object network MY-RANGE-OBJ
range 172.16.1.100 172.16.1.120
object network MY-INSIDE-NET
subnet 10.0.0.0 255.255.255.0
ASA1(config)# object network MY-INSIDE-NET
ASA1(config-network-object)# nat (inside,outside) dynamic MY-RANGE-OBJ
ASA1(config-network-object)# sh ru | i nat
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
ASA1(config-network-object)# nat (inside,outside) dynamic MY-RANGE-OBJ interfa
ASA1(config-network-object)# nat (inside,outside) static interface
WARNING: All traffic destined to the IP address of the outside interface is being redirected.
WARNING: Users may not be able to access any service enabled on the outside interface.
Why I can't add 'dynamic MY-RANGE-OBJ' or 'dynamic MY-RANGE-OBJ inter' ? I can't see any errors, the commands are ignored
Thank you
Hubert
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Super Bronze
Can you rather post the output of
show run nat
Even though I guess your command should list it also.
You can also configure the same in this way (which is the way I prefer doing it)
This IS NOT inserted under any "object"
nat (inside,outside) after-auto source dynamic MY-INSIDE-NET MY-RANGE-OBJ
- Jouni
Super Bronze
Re: ASA 8.4(2) NAT problem
Yes, to my understanding the configuration you mention should work.
We have a firewall running that same software version and generally we have not faced any NAT related problems. Though we dont really use the Network Object NAT / Auto NAT to configure it.
Here is one Bug that seems to match your problem. Though the listed software refers to the ASASM modules starting software and not this software level. But can't be sure the Bug ID notes contain all the information
https://tools.cisco.com/bugsearch/bug/CSCty36464
Picture (click to enlarge)
- Jouni
Super Bronze
show run nat
- Jouni
ASA1(config)# object network MY-RANGE-OBJ
ASA1(config-network-object)# range 172.16.1.100 172.16.1.120
ASA1(config-network-object)# object network MY-INSIDE-NET
ASA1(config-network-object)# subnet 10.0.0.0 255.255.255.0
ASA1(config-network-object)# nat (is
ASA1(config-network-object)# sh run nat
ASA1(config-network-object)# end
ASA1# sh run nat
ASA1#
ASA1#
ASA1# sh run | b obje
access-list OUT extended permit icmp host 172.16.1.2 host 10.0.0.10
pager lines 24
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
Any idea ?
You're right, below command works fine:
ASA1(config)# nat (inside,outside) after-auto source dynamic MY-INSIDE-NET MY-RANGE-OBJ
ASA1(config)# sh run nat
ASA1(config)#
By cisco doc the first version should work as well (
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/nat_objects.html#wp1106144
), is it bug ?
Thanks!
Super Bronze
- Jouni
Thanks for the bug details
cheers!
Super Bronze
You can naturally try updating the software and see if that takes the problem away. I do remember testing the NAT configuration in the same way you attempted it in your original post and it has worked.
You could for example consider newer softwares in the same Major and Minor release. For example 8.4(5) or 8.4(6)
Here is a list of software leves and feature additions/changes in them
http://www.cisco.com/en/US/docs/security/asa/roadmap/asa_new_features.html
- Jouni
667
