ASA 8.4.3 - Traceroute returns same hop throughout
We recently attempted an upgrade from 8.2.3 to 8.4.3 and one of the issues we experienced was an issue with traceroute through the firewall.  Instead of the normal traceroute output, each hop is the same IP.  But the traceroute completes successfully.
Seems like this bug: CSCtj50797  but this bug is supposed to be fixed in 8.4.1 and above.  Anybody have a similar experience?
I am also facing the same problem. Upgraded from 8.2.3 to 8.4.3 and this one is bugging me.
Anyone have any luck with this one? Having the same error here as well with the same OS version.
Bronze
I could not find a documented bug for this, but seems like enabling
inspect icmp and inspect icmp error fixes the issue.
Felipe.
967
