Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA 8.4(4) failover issue
Hi guys,
I'm having a strange behaviour in an ASA cluster running 8.4(4) regarding failover feature, from the Active node standpoint if I issue a "show failover" I have the following result
------------------ show failover ------------------
Failover On
Failover unit Primary
Failover LAN Interface: dmz_failover GigabitEthernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 3 seconds
Interface Poll frequency 1 seconds, holdtime 5 seconds
Interface Policy 1
Monitored Interfaces 2 of 160 maximum
failover replication http
Version: Ours 8.4(4), Mate 8.4(4)
Last Failover at: 13:12:39 UTC May 6 2014
    This host: Primary - Active
        Active time: 1247 (sec)
        slot 0: ASA5520 hw/sw rev (2.0/8.4(4)) status (Up Sys)
          Interface internetwork.wan (192.168.236.99): Normal (Monitored)
          Interface A.dmz (192.168.236.33): Link Down (Not-Monitored)
          Interface B.dmz (192.168.236.1): Link Down (Not-Monitored)
          Interface C.dmz (192.168.236.65): Link Down (Not-Monitored)
          Interface xerox.network (192.168.1.20): Normal (Monitored)
          Interface management (0.0.0.0): Link Down (Not-Monitored)
        slot 1: empty
    Other host: Secondary - Standby Ready
        Active time: 0 (sec)
          Interface internetwork.wan (192.168.236.100): Normal (Monitored)
          Interface A.dmz (192.168.236.34): Normal (Not-Monitored)
          Interface B.dmz (192.168.236.2): Normal (Not-Monitored)
          Interface C.dmz (192.168.236.66): Normal (Not-Monitored)
          Interface xerox.network (192.168.1.21): Normal (Monitored)
          Interface management (0.0.0.0): Normal (Not-Monitored)
        slot 1: empty
Regarding the following interfaces:
--> A.dmz
--> B.dmz
--> C.dmz
This dmz's are sub-interfaces associated to the same physical interface, that are in shutdown mode, from the switching interface they are also in shutdown mode.
So I understand from the active node standpoint we have a "Link Down" situation, but I don'e understand how can this be in "normal" state from the failover node stand point
Bruno Fernandes
Everyone's tags (1)
Hi Bruno, Its look to be L2
Hi Bruno,
Its look to be L2 issue. Please check the vlan is created and extended in the switches
Hi Yadav, The physical
Hi Yadav,
The physical interfaces associated with those dmz's/sub-intf is in shutdown mode…..so that's not the reason from my point of view
Bruno
Hall of Fame Super Silver
Are the interfaces excluded
Are the interfaces excluded from failover monitoring in the config? ("no monitor-interface dmz")
Hi Marvin, Yes does
Hi Marvin,
Yes does interfaces are not monitored, has a side note does dmz's are not being use now….also I don't have a specific "no monitor dmz" in the config !!!! but I'm 100% positive that I have uncheck the box regarding the monitoring option for does dmz's (in ASDM) ……but I will try
BF
I haven't a spare pair to try
I haven't a spare pair to try it on but I suspect your earlier comment about them being shutdown will exclude them from monitoring - even without the "no monitor-interface ___" command. That would make sense since if they are configured shutdown there's no way they will be up on either the active or standby unit.
...so bottom line would be that what you see in "show failover" is completely normal.
146
