ASA 8.4 failover interface testing issue
Team
From ASA 5520 we tested the interface failover it not working even the interface are getting monitor .
primary is active.
Manually we shut the outside interface of the primary device configuration is getting reflecting in secondary as outside interface shut. Interface failover not happen.
ii All the interface are getting monitor when we gave command sh failover. even though when we shut outside interface failove not happening.
kindly tell us how to do the interface failover in ASA 8.4 version.
Sudharsan.R
1 ACCEPTED SOLUTION
Red
Do you have the interfaces as monitored interface, can you provide the output of "show run failover" and "shwo failover"
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Red
Varun
hi varun here is the output
xxxxx-asa-01/pri/act# sh failover
Failover On
Failover unit Primary
Failover LAN Interface: xover GigabitEthernet0/3 (up)
Unit Poll frequency 1 seconds, holdtime 3 seconds
Interface Poll frequency 3 seconds, holdtime 15 seconds
Interface Policy 1
Monitored Interfaces 6 of 160 maximum
Version: Ours 8.4(2)8, Mate 8.4(2)8
Last Failover at: 16:39:29 UTC Jan 4 2012
        This host: Primary - Active
                Active time: 5511130 (sec)
                slot 0: ASA5520 hw/sw rev (2.0/8.4(2)8) status (Up Sys)
                  Interface CW-Internet-delivery (62.208.154.20): Normal (Monitored)
                  Interface WAN-transit (192.168.40.4): Normal (Monitored)
                  Interface Platform-Management (10.13.48.138): Normal (Monitored)
                  Interface Colo (10.128.128.193): Normal (Monitored)
                  Interface Blue-Coat-outer (10.128.128.65): Normal (Monitored)
                  Interface Blue-Coat-inner (10.128.128.33): Normal (Monitored)
                slot 1: ASA-SSM-4GE hw/sw rev (1.0/1.0(0)10) status (Up)
        Other host: Secondary - Standby Ready
                Active time: 249370 (sec)
                  Interface CW-Internet-delivery (62.208.154.21): Normal (Monitored)
                  Interface WAN-transit (192.168.40.5): Normal (Monitored)
                  Interface Platform-Management (10.13.48.139): Normal (Monitored)
                  Interface Colo (10.128.128.194): Normal (Monitored)
                  Interface Blue-Coat-outer (10.128.128.66): Normal (Monitored)
                  Interface Blue-Coat-inner (10.128.128.34): Normal (Monitored)
Stateful Failover Logical Update Statistics
        Link : xover GigabitEthernet0/3 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         6286980409 0          3594275    0
        sys cmd         734957     0          734957     0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        4884205    0          6947       0
        UDP conn        11249789   0          8428       0
        ARP tbl         6270111331 0          2843941    0
        Xlate_Timeout   0          0          0          0
        IPv6 ND tbl     0          0          0          0
        VPN IKEv1 SA    0          0          0          0
        VPN IKEv1 P2    0          0          0          0
        VPN IKEv2 SA    76         0          0          0
        VPN IKEv2 P2    12         0          0          0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     0          0          0          0
        Route Session   0          0          0          0
        User-Identity   39         0          2          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       250     3601771
        Xmit Q:         0       1485    6293432921
xxx-asa-01/pri/act# sh runn failover
failover
failover lan unit primary
failover lan interface xover GigabitEthernet0/3
failover polltime unit 1 holdtime 3
failover polltime interface 3 holdtime 15
failover link xover GigabitEthernet0/3
failover interface ip xover 10.99.99.1 255.255.255.252 standby 10.99.99.2
xxxxxx-asa-01/pri/act#
Re: ASA 8.4 failover interface testing issue
please see the output of the device and reply still we face the same issue when we shut the bluecoat outer interface failover not happening.
Sudharsan.R
641
