Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA 8.4 NAT static and dynamic with the same public IP
Hi, in ASA 8.4, I need to use to static nat an internal IP with a public IP and use the same public IP to dynamic nat another internal IP:
nat (inside,outside) source static IP1_PRIVATE IP_PUBLIC
nat (inside,outside) source dynamic IP2_PRIVATE IP_PUBLIC
All outgoing connection from IP1_PRIVATE and IP2_PRIVATE should be natted to IP_PUBLIC and all incoming connection to IP_PUBLIC should be forwarded to IP1_PRIVATE: is it correct ?
thank you in advance
greatings
rs
Everyone's tags (2)
As soon as the inbound connection is using a different port from the connections created for the outbound connection that should work.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Community Member
Re: ASA 8.4 NAT static and dynamic with the same public IP
it's necessary to migrate from a check point solution that allows that.
thanks
Hello ,
It is completeley difficult that an outbound and inbound connection trough the ASA share the same port because remember that connections innitiaded on your inside host will use a random port so do not worry for that.
Please rate helpful post.
Have a great day,
Julio
Julio Carvajal
695
