ASA 8.4 port forwarding issue
Hi all! I have ASA 5505 with 8.4(2)8 software for one of my branch offices and I can't configure port forwarding It seems to be very simple, but it's not working. I use my ASA as a gateway to the internet for users in office and for site-to-site IPSec VPN to HQ. I have pppoe-enabled outside interface, but ISP gives me static routable ip address. I have server behind my firewall and I should "publish" to the WAN some of its' tcp and udp ports, but I see that no packets forwarded through ASA. I tried to configure PAT as stated in official "Cisco Security Appliance Configuration Guide" through CLI and ASDM. I also used this video(same ASA and ASDM versions) by Cisco TAC's Mike Robertson.
While troubleshooting, I put permit-any-any rules on both interfaces and permitting rule for traffic to the outside interface.
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any interface outside
access-list outside_access_in extended permit ip any any
access-list global_access extended permit ip any any
I captured packets on ASA outside interface and I have it there.
1: 05:34:28.193578 802.1Q vlan#20 P0 46.158.x.x.59668 > 213.171.x.x.3389: S 3188198355:3188198355(0) win 8192 <mss 1260,nop,wscale 2,nop,nop,sackOK>
Here is packet-tracer output
packet-tracer input outside tcp 46.158.x.x 3389 213.171.x.x 3389
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   213.171.x.x  255.255.255.255 identity
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
So, here is my config(output omitted for some parts)
interface Vlan1
nameif inside
security-level 100
ip address 10.10.93.1 255.255.255.0
interface Vlan20
nameif outside
security-level 0
pppoe client vpdn group comlink-pppoe
ip address pppoe setroute
ftp mode passive
object network hq-lan-0
subnet 10.23.16.0 255.255.254.0
object network branch-lan
subnet 10.10.93.0 255.255.255.0
object network hq-lan-1
subnet 10.10.23.0 255.255.255.0
object network hq-lan-2
subnet 10.23.22.0 255.255.254.0
object network moonserver
host 10.10.93.6
!for real pat, will use after troubleshooting
object-group service DM_INLINE_SERVICE_1
service-object object RTP
service-object object SIP
service-object object STUN
service-object tcp destination eq www
!-------------------------inside_access_in---------------
!It's some rules for VPN users
access-list inside_access_in extended permit ip object branch-lan object hq-lan-1
access-list inside_access_in extended permit ip object branch-lan object hq-lan-2
access-list inside_access_in extended permit ip object branch-lan object hq-lan-0
!-------------------------outside_access_in---------------
!Added for troubleshooting as explicit rule for WAN access to outside interface address
access-list outside_access_in extended permit ip object hq-lan-1 object branch-lan
access-list outside_access_in extended permit ip object hq-lan-2 object branch-lan
access-list outside_access_in extended permit ip object hq-lan-0 object branch-lan
!-------------------------for real pat, will use after troubleshooting
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any object krd-itk-vgw1
!------------------------VPN cryptomap acl for traffic encrypting purposes
access-list outside_cryptomap extended permit ip object branch-lan object hq-lan-1
access-list outside_cryptomap extended permit ip object branch-lan object hq-lan-2
access-list outside_cryptomap extended permit ip object branch-lan object hq-lan-0
!-------------------------VPN-related
nat (inside,outside) source static branch-lan branch-lan destination static hq-lan-1 hq-lan-1 no-proxy-arp route-lookup
nat (inside,outside) source static branch-lan branch-lan destination static hq-lan-2 hq-lan-2 no-proxy-arp route-lookup
nat (inside,outside) source static branch-lan branch-lan destination static hq-lan-0 hq-lan-0 no-proxy-arp route-lookup
!------------------------Let users get internet access
nat (inside,outside) source dynamic branch-lan interface
!------------------------Here is my server!!!
nat (any,outside) static interface service tcp 3389 3389
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group global_access global
2 ACCEPTED SOLUTIONS
Re: ASA 8.4 port forwarding issue
Hello Andrey,
Please remove the following configuration:
no nat (any,outside) static interface service tcp 3389 3389
object service RDP
service tcp source eq 3389
nat (inside, outside) 1 source static moonserver interface service RDP  RDP
Also please remove the following access-list:
no access-group global_access global
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Andey,
My pleasure,
I would say it was the NAT.
Julio
Do rate all the helpful posts!!
Hello Andrey,
object service RDP
Julio
Thanks, jcarvaja! You are a magician!!! )))
So, was it trouble in access-list or nat rules order or I made two mistakes?
Hello Andey,
My pleasure,
Julio
3133
