ASA 8.6 und nat
Hey,
in the LAN have a Mail Server ! No Mails come's from the Internet !
What is wrong ?
object network srv-ex
host 10.104.1.9
object service mail-serv
service tcp source eq smtp destination eq smtp
nat (inside,outside) source static any any destination static srv-ex srv-ex service mail-serv mail-serv
access-list outside_access_in extended permit tcp any 10.104.1.9 255.255.255.255 eq smtp
ASA 8.6 und nat
Hello Bodo,
Change the object to source
service tcp source eq smtp source eq smtp
Remember to rate all the helpful posts,
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
ASA 8.6 und nat
Hey,
i have change to :
Nothing works !
Super Bronze
ASA 8.6 und nat
The NAT is incorrect.
It should be:
  host 10.104.1.9
  nat (inside,outside) static service tcp 25 25
ASA 8.6 und nat
Hey,
i have config this then come this :
ERROR: Address xxx.xxx.xxx.xxx overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
What is that ?
Red
ASA 8.6 und nat
Try this:
host 10.104.1.9
service tcp destination eq 25
nat (outside,inside) source static any any destination static interface srv-ex service mail-serv mail-serv
access-list outside_access_in extended permit tcp any host 10.104.1.9  eq smtp
I am using the outside interface as the public ip for the mail server, if you have any other free ip, you can use it.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
Red
ASA 8.6 und nat
Can you also give us the output of :
show run interface
Varun Rao
Security Team,
Cisco TAC
ASA 8.6 und nat
Internet and VPN Site-to-Site works with the Interface !
ASA 8.6 und nat
Hey,
no works, this was the config :
service tcp destination eq smtp
host 10.104.1.9
access-group outside_access_in in interface outside
show nat
Manual NAT Policies (Section 1)
1 (inside) to (outside) source dynamic any interface
    translate_hits = 1058, untranslate_hits = 212
2 (inside) to (outside) source static RFC1918 RFC1918   destination static RFC1918 RFC1918 description NAT-Excempt for VPN
    translate_hits = 0, untranslate_hits = 828
3 (outside) to (inside) source static any any   destination static interface srv-ex service mail-serv mail-serv
    translate_hits = 0, untranslate_hits = 0
Make from the Internet a telnet on port 25 nothing !
ASA 8.6 und nat
Hey all,
have change the NAT Rules from Position 3 to 1 and now works !
Red
ASA 8.6 und nat
Great, it must be hitting your nat exempt..all the best
Varun Rao
Security Team,
Cisco TAC
516
