ASA 84(4) port fwd trouble
Just got a new ASA and is prepping it before throwing it out live.
But i cant seem to get the forwarding to function properly.
I have followed http://www.gregledet.net/?p=529  and read to numerous topics but i cant seem to figure outwhy it aint working.
I have a computer on the outside interface on ..224.1
its connected to ..224.20 (outside)
Inside is 192.168.0.1
another computer with a web server on 192.168.0.5:80 is connected to inside.
Tested the webserver on the inside.
I can ping from the webserver to the ..224.1.
and from the ..224.1 to ..224.20
The log says:
Source ..224.20
Source port 1339
dest port 80
descr.  TCP access denioed by ACL from ..224.1/1339 to outside:..224.20/80
sh run says:
ASA Version 8.4(4)
##EDITED OUT##
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 5
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address ..224.20 255.255.255.128
interface Vlan5
no forward interface Vlan1
no nameif
security-level 50
ip address dhcp
ftp mode passive
clock timezone GMT 0
dns domain-lookup inside
dns server-group DefaultDNS
name-server 192.168.0.13
name-server 194.19.2.11
name-server 194.19.3.11
##EDITED OUT##
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Webserver
host 192.168.0.5
access-list outside_access_in extended permit tcp any object Webserver eq www
pager lines 24
logging enable
logging monitor debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) static interface service tcp www www
route outside 0.0.0.0 0.0.0.0 ..224.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
##EDITED OUT##
console timeout 0
management-access inside
vpn-addr-assign local reuse-delay 5
dhcpd auto_config outside
dhcpd address 192.168.0.100-192.168.0.130 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Everyone's tags (4)
1 REPLY
as always shoot the admin (me)
I logged in with asdm and moved the NAT rule to the top above allow the generic allow all outside.
Everything worked.
Doh!
310
