Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA 9.1.2 configuration supporting etherchannel and VRF routing
Hi All,
I am in the process of setting up a Test and Dev network that must support and separate multiple projects.  I have to build a WAN infrastructure that supports these scenarios.  The plan is to user VRFs to create separate route domains for separation.  I have an ASA 5510 running 9.1.2 that is planned to support inter-network routing between projects, if necessary.  It also is separating Test/Dev from Office network.  Finally, it is to provide remote access to various guests to access their respective project only.
I would like to get your thoughts on the best design of the ASA to support such a scenario.  My initial thoughts are to etherchannel the 2 Gigabit interfaces and build subinterface to support each VRF.  Is this viable or would you suggest a different configuration.
Thank you
Everyone's tags (4)
Hello Forrest,
I think the VRF solution will fit your needs while the ASA with the port-channel will provide redundancy plus security.
You could also run the ASA on multiple-context to split the domain across all of the devices.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Re: ASA 9.1.2 configuration supporting etherchannel and VRF rout
Thank you for the feedback. I have not had the opportunity to work with multi-context before and will research.
Silver
HI Forrest,
You can find related info on the link mentioned below:
https://docs.google.com/document/d/12dyycF9ZGhqOJcfQZydN3d7cPCSXxzS6uWSctbFOu7s/edit
Anim Saxena
Community Manager
9527
