ASA 9.1 - static NAT problem
Hi everyone,
I wanted to create a static NAT by following Cisco's documentation for ASA 9.1 firmware. Inside network is using PAT without any issues but  ASA is not doing NAT for some internal servers from outside. I tried to troubleshoot but I have nothing else left to check. Can you please look at my config and let me knnow if there is anything wrong? I am trying to use permit all ACL until my config works. Thanks.
ASA Version 9.1(4)
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
multicast-routing
interface GigabitEthernet0/0
nameif INSIDE
security-level 100
ip address 10.10.1.5 255.255.255.252
ospf message-digest-key 1 md5 *****
ospf authentication message-digest
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
speed 100
duplex full
nameif OUTSIDE
security-level 0
ip address 1.4.18.194 255.255.255.192
interface Management0/0
shutdown
no nameif
no security-level
no ip address
boot system disk0:/asa914-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name net
same-security-traffic permit intra-interface
object network WEB
host 10.100.2.104
object network RAS
host 10.100.99.2
object network box
host 10.120.1.201
object network inside_network
subnet 10.0.0.0 255.0.0.0
access-list OUTSIDE_IN extended permit icmp any any
access-list OUTSIDE_IN extended permit ip any any
access-list OUTSIDE_IN extended permit gre any any
mtu INSIDE 1500
mtu OUTSIDE 1500
ip verify reverse-path interface OUTSIDE
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-715.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
object network WEB
nat (INSIDE,OUTSIDE) static 1.4.18.195
object network RAS
nat (INSIDE,OUTSIDE) static 1.4.18.196
object network box
nat (INSIDE,OUTSIDE) static 1.4.18.198
nat (INSIDE,OUTSIDE) dynamic interface
access-group OUTSIDE_IN in interface OUTSIDE
router ospf 10
router-id 10.10.1.5
network 10.10.1.4 255.255.255.252 area 0
log-adj-changes
default-information originate metric 95
dynamic-access-policy-record DfltAccessPolicy
service resetoutside
tls-proxy maximum-session 1000
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect pptp
  inspect icmp
  inspect ipsec-pass-thru
  inspect mgcp
  inspect http
service-policy global_policy global
prompt hostname context
  • Firewalling
Super Bronze
I would start with testing the NAT that is not working with "packet-tracer" command.
Simulate/Test some connection coming from the public network with the command
packet-tracer input OUTSIDE tcp 1.1.1.1 12345
You did not mention the Static NAT that is not working (unless the problem is with all of them) so insert the correct NAT IP to the above command.
Do you have a default route configured on the ASA at all? I can't see it in the above output atleast.
Have you checked the ASAs routing table? Does it include the source address of the Static NAT that is working? Just wondering if there is a routing problem.
- Jouni
Hi Jouni,
yes there is a static route (it is deleted from the config posted by accident) pointing to the outside interface.
Problem is with all of Static NAT entries. I do not have any issues with any internal routing and I can easily ping my outside gateway.
I will try packet-tracer and see what it shows.
John
I've found out after checking with packet tracer, it looks like inbound connection is failing because of rpf-check. how can I make sure that return traffic from servers follow back their original NAT connection?
John
Super Bronze
The most common reason that the "packet-tracer" might fail with the RPF Check is if you use the actual private IP address as the destination in the "packet-tracer" command.
That or some problems with the NAT configurations but that doesnt seem likely considering your simple NAT configuration.
It would still help to see the actual "packet-tracer" output I suggested originally.
You should be seeing an UN-NAT Phase at the very start of the output which would tell the destination address of the "packet-tracer" matches one of your NAT configurations. Then you should see a ACCESS-LIST Phase which shows an interface ACL allowing the connection.
- Jouni
Silver
Your internal servers are reachable on a particular port? For instance 80/443?
The NAT statements are fine to me, very basic.
Your access-list is wide open, no problem either.
Try from another internetconnection to telnet to one of your public IP-adresses on a open port 80/443.
Posted by WebUser Erik Boss from Cisco Support Community App
yes my internal servers are reachable, I do not have any other firewall on the servers blocking those ports. I do not think I have any routing or firewall problem. I do not know what I am missing.
John
1560
