Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ASA Active/Active configuration
All,
When you use an AA or AS configuration, and these devices connect to the internet, do you have to burn two public IP addresses? Do they look like one address with a virtual IP?
John
HTH, John *** Please rate all useful posts ***
Re: ASA Active/Active configuration
Yes You use two IP addresses.
The IP address configured as Primary always sticks with the ACtive Firewall.
Syed
Hi John,
Either in Active/Standby or Active/Active modes, two public IP addresses are needed.
However, the public IP on the Active firewall will be used for traffic, while the one on the standby will be used to continously check the failover between the Active and the standby firewalls.
cheers.
125
