ASA and FQDN?
I've been tasked with converting a Netscreeen fw to ASA 5520. All is well except for some of the fw policy where they have used fqdn for a host in the "untrust" portion of the policy. On the netscreen, you can configure a dns server and it will go out and resolve these fqdn's. Does the ASA allow for something like this? I've looked through the cmd reference, etc and haven't found it.
greg
Re: ASA and FQDN?
Re: ASA and FQDN?
sorry doesn't apply.
I'm asking about the ability to use a fqdn either directly in an access-list (aka policy statement) or a network-object that can be used in an access-list.
Silver
Re: ASA and FQDN?
Hi ggriebel,
If I am not mistaken, what you're trying to do
here is to use what to refer in checkpoint
or Juniper/Netscreen as "domain" objects. In
other words, you specify the domain object as,
for example, ".yahoo.com" and take this object
and apply to either source or the destination.
Furthermore, sometime you want to "negate"
the object as well.
Those features have been widely available
with Checkpoint and Juniper firewalls. Cisco
Pix/ASA does not support that function.
CCIE Security
Re: ASA and FQDN?
It can also be done on Fortigates. I didn't think it's available on the ASA, that's why I was questioning.
thanks.
ASA and FQDN?
I want to follow up on this thread to see if Cisco has made any update on this - Access policy using FQDN instead of hard coded IP address?
I have seen couple of options based on my research.
MPF with http class -- > this is not good enough as https or non http traffic will net be qualified.
Identity ware firewall policy using DNS--> Is this applicable to 8.2 release
REgards
PRatheesh
978
