Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ASA and PAT
There are 2 things I would like to ask.
1st - my understanding of PAT ( port address translation ) if I have 1 public IP address lets say 1.1.1.1 for example and have 3 internal servers 192.168.1.1 .2 and .3 can I use the same public IP to map different services E.G 3389 to 192.168.1.1 443 to 1.2 80 to 1.3 using the 1 public IP?
The one thing I'm guessing that can't be done on 1 public IP is map the same service to multiple servers so 3389 to 192.168.1.1 .2 and .3?
Please confirm?
Thanks.
You are correct, we cannot
You are correct, we cannot use PAT in that manner. We need to have static NAT to allow a user from the outside to reach a specific machine (i.e., 192.168.1.2:3389).
We use PAT to conserve our Public IP Range/s.
PAT would be
object network Inside
subnet 192.168.1.0 255.255.255.0
nat (inside,outside) dynamic interface
Now when any client on the Inside (192.168.1.0/24) tries to get to the Internet, they will be PAT to the outside IP of the ASA.
Static NAT would be
object network PublicIP
host 108.1.1.252
object network RDP-Server1
host 192.168.1.2
nat (inside,outside) static PublicIP service tcp 3389 3389
So I can do what I said first
So I can do what I said first as in map 1 public IP to multiple internal as long as there on different ports?
Hi,Yes , you are correct.For
For Ex:-
If you have 3 Server and 1 Public IP:-
LAN IP:- 10.1.1.1 , 10.1.1.2 and 10.1.1.3
Public IP:- 2.2.2.2
You can do something like this:-
host 10.1.1.1
object network RDP-Server2
host 10.1.1.2
nat (inside,outside) static PublicIP service tcp 3389 3390
object network RDP-Server3
host 10.1.1.3
nat (inside,outside) static PublicIP service tcp 3389 3391
Thanks and Regards,
Vibhor Amrodia
62
