ASA Bandwidth Monitoring
Hi guys,
Is there any why to identify the source and destination of large traffic going across a Cisco ASA Version 8.0(4)
For example if we run a 5Mo to internet across the firewall, we can receive a log with the source and destination IP addresses information and the job they run as well (HTTP or ftp...)
i know we can do that using MPF, but that cause limiting the traffic and log the action. we dont like to do any action , just keep it more thatn 5 Mo and we see who is doing that .
Everyone's tags (4)
Re: ASA Bandwidth Monitoring
Hello
I hope you are doing great, you can have the MPF option and when you do the action thing, you can put allow instead of putting a drop action. Another thing that you can do is to upgrade your device and use Netflow, that would give you more granular information and you can build reports based on traffic flow passing through the ASA.
Hope this helps.
Mike
Mike
Maykol,
Thanks for the information, but Netflow required buying a license and I don’t thank that s going to work for me.
Pkampana,
Thanks for that, I did use ASDM to see the Dashboard in top talkers section, but that not present exactly what I like to see, what we are looking for is some thing like (Source IP Address, Destination IP address, Job using) ??
Also, by any chance could you tell me if there is a way to send an email notification from the firewall if we get to the targeted bandwidth?
Thanks a lot
No license is needed, and also there is some free servers that you can use.
http://www.cisco.com/en/US/prod/iosswrel/ps6537/ps6555/ps6601/networking_solutions_products_genericcontent0900aecd805ff72b.html
Hope this helps
Mike
Mike
If you have threat detection enabled (it is by default) you can open ASDM and in the first tab it has a "top talkers" graph. That will show you people that see the most traffic. You can edit the graphic look and feel.
I hope it helps.
PK
13476
