ASA basic configuration help
vincehgov
I'm running into an issue where I cannot even access the internet from the inside network.  I did a capture on the ASA.  The inside interface shows pings from the internal host to the internet but nothing coming back.  The same capture on the outside interface shows the host natted to the outside interface's IP address.  It shows the host sending the pings to the internet and it also shows the ping replies coming back to the outside interface's IP address.  So, I know the pings are going from inside to outside and natted properly.  But for some reason, the ASA is not allow the traffic back in.  Here's my configuration.  Can someone enlighten me?  This is for a client so I hid his IP address.
: Saved
ASA Version 8.2(5)
hostname ASA
domain-name x.org
names
interface Ethernet0/0
switchport access vlan 98
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan2
nameif inside
security-level 100
ip address 192.168.148.2 255.255.255.0
interface Vlan98
nameif outside
security-level 0
ip address <>
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns server-group DefaultDNS
domain-name x
access-list CAP1 extended permit ip any host 8.8.8.8
access-list CAP1 extended permit ip host 8.8.8.8 any
pager lines 24
logging enable
logging timestamp
logging buffer-size 51200
logging asdm-buffer-size 500
logging monitor informational
logging buffered errors
logging history errors
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 <> 1
route inside 192.168.150.0 255.255.255.0 192.168.148.1 1
route inside 192.168.151.0 255.255.255.0 192.168.148.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable 8443
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
no call-home reporting anonymous
Jouni Forss
Like in another thread it would seem that you are missing the inspection configurations. Have you completely removed the "policy-map" configurations.
If you have then you could try adding the following
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect icmp error
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect rtsp
  inspect skinny
  inspect icmp
  inspect esmtp
service-policy global_policy global
- Jouni
Jouni Forss
parameters
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect icmp error
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect rtsp
  inspect skinny
  inspect icmp
  inspect esmtp
- Jouni
Thank you.  that was it.
Basically what was causing the ICMP not to go through completely was missing the "inspect icmp" configurations.
Without them the ASA will let the ICMP Echo messages from behind the ASA pass to the Internet. Provided ofcourse the "security-level" or the "access-list" allow that.
However, the Echo Reply message would be blocked by default.
The solution to that is the above adding of "inspect icmp" (although the above contains a lot more)
Other alternative would have been to allow "echo-reply" messages in a "outside" interface ACL.
- Jouni
Thanks for the explanation. I suspected it was something like this. I looked up as many ASA "basic" configuration for Internet connectivity I could find and all they had were dynamic pat. Thanks!
