asa block existing connection
Right now I have a rule that allows ICA connections for citrix.  We would like to have the ability to stop new connections but not terminate existing ones immediately.  If I disable the permit will it terminate all the existing entries in the conn table and kill the active sessions?
1 ACCEPTED SOLUTION
VIP Purple
You can change the ACL as you
You can change the ACL as you want and your existing connections stay as they are. ACL-entries are only evaluated for new connections.
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
1 REPLY
VIP Purple
50
