Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
ASA blocks Traffic non-SIP over SIP port 5060 (TCP) ?
Hi all,
we experience this issue in our network:
a test probe is running ftp requests to a server in order to measure performance between two point of the network.
The ftp uses port TCP:5060 that is a well known port for SIP. The easy conclusion that it is a non sense and that this ftp test should change its connection port is not enough for some people, it is mandatory to make this test work with this configuration. We are trying to understand where should this dirty connection be aborted, the first security device is ASA. ASA has SIP inspection enabled and, as I understood, it considers UDP/TCP:5060 by default (even if in most cases SIP runs over UDP).. is it possible that this inspection block FTP traffic over SIP port? We would maintain SIP inspection active while enabling this FTP traffic: I found the SIP inspection parameter 'traffic-non-sip', could it help with our issue?
An additional information is that ftp client generates SYN but it doesn't receive any SYN ACK: if something blocks, it blocks from the very beginning of the connection.
Thanks a lot
Re: ASA blocks Traffic non-SIP over SIP port 5060 (TCP) ?
SIP clients use both TCP or UDP (depending on the implementation), as stated here:
http://en.wikipedia.org/wiki/Session_Initiation_Protocol
Try disabling all SIP/VOIP related inspections and see if it helps.
Please rate if helpful.
Farrukh
Community Member
by disabling SIP inspection we make FTP connection on port 5060 work, but this is not what we desire: if we disabled SIP inspection, SIP connections wouldn't work anymore and we see such connections passing through our network.
Just to update what I wrote, by doing 'sh run all' I realized that non-sip traffic on sip port is enabled by default by ASA:
policy-map type inspect sip _default_sip_map
description Default SIP policymap
parameters
  im
  no ip-address-privacy
  traffic-non-sip
  no rtp-conformance
but it seems not to be enough.
That command should do it (its enabled by default). I suspect you are hitting a bug.
I would recommend to open a TAC Case for this (if chaning the FTP port is not an option). There have been numerous bugs on ASA OS related to SIP inspection.
Farrukh
Bronze
Did the problem got fixed?
Luis Sandi
P.S Please mark this question as answered if it has been resolved. Do rate helpful posts.
3032
