ASA Command change help
HI guys,
Iam trying to configure VPN and need to change the following command to fit in image asa724-k8;
nat (inside,outside) 1 source static net-local destination static net-remote net-remote
This is an old command.
I need you help.
Everyone's tags (4)
1 REPLY
Super Bronze
It depends on the current NAT configuration on the ASA running 7.2(4)
For example does it have any existing NAT0 configurations?
Also we dont know what networks those objects like "net-local" and "net-remote" contain so its impossible to say the exact corresponding configuration.
The configuration format would be
access-list INSIDE-NAT0 permit ip
nat (inside) 0 access-list INSIDE-NAT0
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more if needed.
- Jouni
207
